FF-8000vsVinf8mk2 |
Page 123 6> |
Father-Francis
Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2758 |
Topic: FF-8000vsVinf8mk2Posted: 21 July 2008 at 7:39pm |
http://www.noisecontrolaudio.com/pdfdatasheets/FULL_FREQUENCY.pdf
http://www.voidaudio.com/product_detail.asp?id=31 i know the prices of the voids what do the FF-8000 cost which would be best to run 8 hogs loaded with v18-1000 ![]() |
Tedski
Joined: 15 December 2006 Location: Netherlands Status: Offline Points: 453 |
Posted: 21 July 2008 at 8:55pm |
I know what your vans suspension and your back thinks about that
Father-Francis
Posted: 21 July 2008 at 9:13pm |
![]() i think they weigh like 100kgs (the hogs)can´t fit them in the vanback to the amps
simo69
Joined: 29 September 2005 Location: United Kingdom Status: Offline Points: 1896 |
Posted: 21 July 2008 at 10:54pm |
do you mean FFA8000? http://fullfataudio.com/
Edited by simo69 - 21 July 2008 at 10:55pm |
simo69
Posted: 21 July 2008 at 11:00pm |
Just save your pennies and buy a new FFA8000..!!! 4k per channel @ 2ohms.. job done,
Edited by simo69 - 21 July 2008 at 11:10pm |
Marios
Joined: 20 July 2007 Location: Manchester UK Status: Offline Points: 602 |
Posted: 22 July 2008 at 3:30am |
Whats the price on these?
Father-Francis
Posted: 22 July 2008 at 5:18am |
this is what I was looking at FF8.0 8KW Producing up to 4000W per channel and with ability to really drive 2 Ohm impedance loads without sacrificing sound quality Noise Control Audio amplifiers deliver awesome performance in lightweight standard 2RU packages. Three amplifier models are available using high efficiency cool operation Class D amplifier topology All FF amplifiers are ideally suited to drive ' 2 Ohm' loads in the most demanding applications thus giving best amplifier to loudspeaker ratio. The FF-8.0 offers ultimate low frequency amplification for specialist high power sub bass systems. Designed and manufactured in England. looks like the one you show there but this one´s from WWW.NOISECONTROLAUDIO.COM how do they cost? |
Phil B
Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2353 |
Posted: 22 July 2008 at 10:10am |
Same amp, different faceplates.
Talk to Dave M ( or via the FFA site) on here or give NCA a ring...? Both will give you a price. .p. |
simo69
Posted: 22 July 2008 at 11:42am |
The FF8.0 is identical to FFA-8000 performance wise. They manufacture the FF3.6 FF6.0 FF8.0 for Noise Control Audio as an OEM product. It has a grey front panel and handles with blue leds to match the speakers they make.
Peter Moller
Joined: 26 December 2005 Location: Denmark Status: Offline Points: 2531 |
Posted: 22 July 2008 at 12:15pm |
If you want to try the Inf8V2 - give me a shout - I have got one sitting in my garage near Aarhus..
/peter
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
sKs01
Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
Posted: 22 July 2008 at 1:06pm |
well i think a shootout is needed at some point as looking at it on paper the infinite wins, the smps per chanel on the FFA are rated at 10A max, the infinite can draw 32A and is 90% efficient, unless FFA have made some insane level of efficiency from their offering that limited current draw will let it down, peak to peak performance seems to still be gained by the caps not by a massively supped up psu IMO, having only ever seen the specs for the ffa8 though this is nothing more than conjecture so id still like to see a proper dub condition test
Dave M
Joined: 12 December 2007 Status: Offline Points: 144 |
Posted: 22 July 2008 at 2:32pm |
FFA amplifier's output watts are measured rms volts across resistive load 2/4/8 ohms and are not measured peak to peak. Both channels are independant, so when both are driven power performance is not affected when both channels driven simultaneously.
All the best
Dave
Page 123 6> |
