HD15 honking help |
Page 12> |
dgm606
Topic: HD15 honking helpPosted: 03 August 2024 at 6:41pm |
1
Edited by dgm606 - 10 August 2024 at 6:09am |
Teadub
Joined: 13 April 2019 Location: Highlamds Status: Online Points: 46 |
Posted: 03 August 2024 at 8:37pm |
which drivers are in them and what at what frequencies have you tried to xo?
dgm606
Posted: 04 August 2024 at 1:51am |
1
teeth
Posted: 20 August 2024 at 7:05pm |
set your upper xo lower, sub 140 also put some more info in your posts please
1ManSoundsystem
Posted: 16 July 2025 at 1:43am |
honk honk !
BrainlessTekno
Joined: 20 February 2023 Location: Slovakia Status: Offline Points: 381 |
Posted: 16 July 2025 at 8:16am |
im glad this post was brought up, lot of interesting info here
BarSick / barsik soundsystem
Dont want to toot my own horn but toot toot |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 02 August 2025 at 7:16pm |
![]() Above graph suggests, flattening eq of approx -3db@150hz, with q of approx 0.5 would be a good start. If none of the above makes any sense, or you are using horn loaded cabs, without LMS, maybe time to reconsider, if Sound/Mobile PA is for you.
![]() Edited by levyte357- - 02 August 2025 at 7:25pm |
paulus
Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3237 |
Posted: 04 August 2025 at 11:25am |
i used hd15 for 10 years loaded with pd154( mad bl for a 15 inch ) and time aligned to my scoops , i cut them 75 to 125 and they were bloody good indeed
Edited by paulus - 04 August 2025 at 11:26am |
TRENDSETTER SOUND SYSTEM
levyte357-
Posted: 04 August 2025 at 1:08pm |
The HD15 unprocessed response, wil almost always have huge peak in the response, making it difficult to hear anything, each side of the frequency peak. A lot of older brand name PA cabs, had a normally peaky, response, but they shipped with dedicated "controllers", that smoothed the response. Looking at older Turbo, FK1 docs, they published recommend smoothing eq settings, for engineers using their own LMS, with these cabs.
Edited by levyte357- - 04 August 2025 at 2:12pm |
KDW32
Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 770 |
Posted: 04 August 2025 at 10:12pm |
4D
Joined: 13 November 2008 Location: Winchester Status: Offline Points: 4364 |
Posted: 05 August 2025 at 4:21pm |
using the elderly turbo tse218/118 I often have a nibble approx -3db at 80hz & 160hz reduces both whoom and honk..
levyte357-
Posted: 05 August 2025 at 11:48pm |
I have a video somewhere, where I flattened the response of a THL-818, after reading Turbo docs, then using standard Fane 18B, was running the cab, 80-400hz... ![]() |
Page 12> |
