Forum Home Forum Home > Plans > X10, X12, X15 and XM15
  New Posts New Posts RSS Feed - X15 plan problem ?
X15 plan problem ?
stephenwconcannon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stephenwconcannon Quote  Post ReplyReply Direct Link To This Post Topic: X15 plan problem ?
    Posted: 03 February 2008 at 6:07pm
the large blue brace on the plan doesnt look right to me, how can the brace come to the front of the box? the driver would be in the way...
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2008 at 9:50pm
It's above the driver. If you're worried about it extend the front, side and rear panels 10-20 mm, keeping the port, top and bottom the same.
angus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote angus Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2008 at 6:38pm
Can anyone send me a link to the plan please?
I'm finally getting round to bracing my x15s ahead of using them above 50W i.e. out and about in earnest for gigs, and I would like to check a couple of measurements and brace placement suggestions (also the alternative drivers) but the main speakerplans site is down still :(
Thanks,
Angus
They're complaining over there, but it's their fault!
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 1:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 1:48pm
The old bits of the site still work....
EDIT: bum links
Edited by Jake_Fielder - 11 February 2008 at 2:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote angus Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 2:07pm
Ta - I actually found it here having posted same query in general forum
Oh, and I can confirm using the bmd450 on the 220 horn with the sn15mb no fouling will accur if you follow the plans!
