  New Posts New Posts RSS Feed - 3 way top plan needed
hansom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hansom Quote  Post ReplyReply Direct Link To This Post Topic: 3 way top plan needed
    Posted: 03 September 2014 at 4:40pm
Looking for a 3 way top plan
speakers im going to be using is:
1 RCF ND850 Driver- 110rms/ 500Hz-20,000Hz
1 RCF 10" L10 750yk - 350rms/ 70Hz-3,000Hz
1 RCF 15" L15S801 - 700rms/ 40Hz-1,500Hz
looking for a plan that would be 3 way and these would play to the best
Bass is 2 RCF 18" P400 - 1000rms/ 25Hz- 1,000Hz each
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2014 at 1:38am
Why dont you make a line array?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hansom Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 1:40am
can a line array work for this setup
if yes can u guide me into a design please
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 5:17am
..your mean! Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 12:29pm
Make a F218 copy box too while you at it. They are giving away the plans anyway.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 12:50pm
I doubt you will find an off the shelf DIY plan to suit those drivers well. You are going to have to do some thinking unless you want to just guess and probably end up with performance that will be a crap shoot.
Design a box around the 15" to get near the SPL and LF extension that will suit you, these factors will influence what type of enclosure you go for. The simplest thing you could do would be to mount all of the drivers in one enclosure (sealed or vented), box off the midrange driver internally, then figure out the volume of the main enclosure in order to meet your original spec whilst compromising on size.
You're not going to get away without some thinking!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 12:59pm
What he has described is exactly the EAW KF850 box. Even if he find some plans he will never be able to make the mid phase plug.
And for gods sake why would you want to make a 100kg top box?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 1:47pm
http://hornplans.free.fr/pas3ma3.html   Embarrassed
Remember plans are for 20mm timber.
Edited by levyte357- - 05 September 2014 at 1:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 1:57pm
Good catch Lev. i totally forgot about that box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 2:14pm
4-5x a year, for the last 5x years, I've considered re-drawing this cab, for 15mm timber, and width  636mm. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2014 at 2:18pm
Redo that box with the hf in the 15 inch horn so it is not that big.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hansom Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2014 at 8:54pm
how would the speakers would work that plan
anyone have a eaw 850 plan? phase plug can be done
but if anyone can help me with the design that would be greatly appreciated :D
