REW to Measure External Noise |
Ted99
Joined: 07 June 2025 Location: Clayton, NC Status: Offline Points: 2 |
Topic: REW to Measure External NoisePosted: 07 June 2025 at 4:18pm |
I would like to use REW to measure noise coming from outside my house which may have some infrasound at high db. Goal is to record and plot db vs and frequency 24/7 for time or elapsed time for a week or two. I don't know if this is possible using REW. If you know of other software to do this I would like to know that also. Thank you for any assist you can give me on this.
Ted
snowflake
Joined: 29 December 2004 Location: Bristol Status: Online Points: 3443 |
Posted: 07 June 2025 at 9:04pm |
you could record with Audacity and then apply some eq to remove all but the infrasound. you should then be able to see on screen any periods of high volume infrasound. What do you think the source might be?
FlipC
Joined: 25 October 2007 Status: Offline Points: 666 |
Posted: 09 June 2025 at 8:51pm |
So 1 problem what are you using to record WITH?
A normal mic will not work. probably cheaper to build one than to buy also. And I think snowflakes idea is on e right track. As the microphone is the main thing. Not the recording software. (no clue how long REW ill record for - only used it for room setup, Now use Open Sound Meter. But most recording software (I use Soundforge) should do what you want |
