Compact 12 inch bass |
Page 123> |
KWB75
Joined: 10 November 2007 Status: Offline Points: 268 |
Topic: Compact 12 inch bassPosted: 10 August 2025 at 9:16pm |
Looking to build a compact 12 inch bass/sub for house parties, is the BMS 12 still the king of compact reflex builds?
Not looking for massive spl, just something solid at 40ish hz and more importantly - a box I can tuck away into a corner. Thanks!
FOO
Joined: 23 December 2018 Location: Denmark Status: Online Points: 954 |
Posted: 10 August 2025 at 9:37pm |
https://www.lean-business.co.uk/SPEAKER_PLANS/CIARE%2012SW%20Bass%20Reflex.pdf
This should fit your bill. It's a good sounding driver. Maybe not as good as BMS, but still good.
Edited by FOO - 10 August 2025 at 9:37pm |
KWB75
Posted: 11 August 2025 at 9:50pm |
Thanks, forgot about that plan.
I don’t have a massive amount of amp power on hand (500w @4ohm) so won’t really do the big boy drivers justice, in small boxes they need a lot of power… Still tempted by the Tony Wilkes Q12 with BMS, it’s so compact ![]() |
fudge22
Joined: 26 July 2022 Location: UK Status: Offline Points: 263 |
Posted: 16 August 2025 at 12:00pm |
If you can get the search function to work, the thread discussing the origins of the Q12 here on the forum. If I remember correctly the suggestion for the BMS driver was a 40 ltr cabinet tuned to 42Hz. The above plans for the Ciare cabinet are 40 ltr tuned to 37Hz. Both the Ciare and BMS drivers will perform similarly in either of the cabinets. I would suggest 40 ltrs at 40Hz, simply because the tuning is not that critical, and the measured tuning will be in the 38 – 42Hz range which is good enough. I have a friend who has used both these drivers in such a cabinet. He says that in in use they are difficult to distinguish, and suggests going with whichever drive unit is either cheaper or more readily available. As a lighter option, the faital Pro 12RS1066 will also work in the same design. |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 16 August 2025 at 5:46pm |
Think I'd be leaving a house party early, if the sub was provided by a single 12" reflex.. ![]() Edited by levyte357- - 16 August 2025 at 5:50pm |
SamV
Joined: 21 October 2008 Location: London Status: Offline Points: 8783 |
Posted: 25 August 2025 at 9:21am |
I'm a big fan of the Q12s. Make for a great house party rig.
Teadub
Joined: 13 April 2019 Location: Highlamds Status: Offline Points: 46 |
Posted: 25 August 2025 at 2:27pm |
Pretty sure the q12 called for a big boost at tuning frequency, if you've got limited amp power available that may be an issue. I built a small reflex 12 with a beyma 12lx60v2 in it which is great for small house parties and the like. The size ended up being based on what ply I had leftover, I think it's around 45l internal. Just had a play on hornresp and ended up tuned to 40hz and it sounds sweet.
levyte357-
Posted: 25 August 2025 at 4:42pm |
For me the, absolute minimum single cabinet solution for a house party, would be something similar to a B&C 1x18, loaded with PD186 (Mk1), or better. This cab works with so many 18" drivers unmodified, but guess would be even better with full 200L internal chamber. ![]() Edited by levyte357- - 25 August 2025 at 4:42pm |
FOO
Posted: 25 August 2025 at 6:09pm |
But it's not all of us who wants to shoot birds with Cruise missiles. |
KWB75
Posted: 25 August 2025 at 7:14pm |
Yeah, i guess we all different views on what constitutes a house party - my needs are more for background music at a decent level that can be turned up if we fancy a dance.
Speakers are always indoors, so with some corner loading a 12 inch bass will definitely do the job.
Lucasdude
Joined: 16 March 2013 Location: London Status: Offline Points: 986 |
Posted: 25 August 2025 at 8:09pm |
I've done a house party with a single 15" reflex and bridged 1k amp behind it. It was a Klipsch KI-115, which used something made by Eminence. Probably similar to a Kappa Pro 15LF, but it had a bigger magnet. It was rated at 400w RMS and it had all the bass the house needed!
levyte357-
Posted: 25 August 2025 at 8:35pm |
Also birds.. ![]() ![]() Some of us "older" Reggae dudes, had pair of Realistic Mach IIs, ADC Soundshaper Eq's, and Technic Class A Amps in our bedrooms as teenagers, rattling the letterbox on the Front door, from our back bedrooms. So the thought of a house party, with sub provided by 1x12" cab, is simply unthinkable.
Page 123> |
