  New Posts New Posts RSS Feed - front loaded 3 way mid tops
opus jody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote opus jody Quote  Post ReplyReply Direct Link To This Post Topic: front loaded 3 way mid tops
    Posted: 04 April 2009 at 1:06pm
Hi.
I've been running the 1st prototype of the opus cs850 for a couple of years now, to good effect. my own hyper-critical criticism of them would be that the high mid & top are fractionally too loud, in that they run about -6dB on the opus amps, compared to the bass which runs at 0dB, which is fine, but i've got a theory that if the speakers were quieter I could run the amps louder, and closer to the limit, so with live music I could rely on the opus amps' limiter to sort out any 'loud bits' in the live music & do away with comp/limiters on a lot of the channels.
Also, the low mid is not really having it on the CS's. I've overcome that up to now by running a 2x15
 'wheelie bin' per side (sometimes 2) up to 180 Hz, and running central subs up to 80Hz.
so, a possible solution:
just one high mid cone per box instead of 2, custom engineered to become a duel concentric for the stunning new opus 1.4" comp. Then both top. (without it's horn) & hi mid should be somewhere around 3dB quieter.
then, as they're both so much smaller, there's space for 2 x 10" bass/low mid cones beneath them. a 3 way box. probably end up passive between the hi mid & top.
here's the 1st one next to a CS850, and also 2 x single cone low mid boxes to compare drivers & compare ported vs sealed.
just waiting for some more samples to turn up.
also had the idea (thanks mykey) of rounding the fronts to minimise edge diffraction, and to make the internals more cylindrical, cylinders being 2nd best to spherical.
I'm not going to go into the drivers used, 2 of them are oem's anyway, at least not for the moment, but it's quite an interesting idea for the diyer as duel concs can be bought complete, and a simpler trap box could be an easy build for anyone.
more to follow after driver & box shape listening tests.
Improvised Hardware Music http://vimeo.com/user9389813/videos
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2009 at 6:13pm
Hi-FiThumbs Up
djcrude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djcrude Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 10:18pm
how are you planing on wireing the sub!!. . . . . . .
1 driver would be at 8ohms
2 drivers would be at 4ohms
3 drivers would be ar 2ohms
but at 2 ohms is it stable?? or is their another way of wireing
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 10:44pm
3 8 ohm drivers would be 2.7ohms.... 3 x 16 ohm drivers in parallel would be 5.3 ohms or so though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 11:42pm
from what i read, he is going to have the new midtops two way active (with a passive split between the midhi and comp).
looks like a lovely concept, and i love the rebated edges, scherical internals etc... Cant wait to hear the finished product.
ps: i really do love your cottage jody, such a nice location and building Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote opus jody Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2009 at 2:37pm
^ what he says.
4 ohms 'bass' (low mid)
8 ohms hi mid
8 ohms HF.
not sure about passive or active mid tops yet. with active it's easier to do time allignment, although it might not be necessary with a duel conc.
with 3 tops a side I should be able to run the 3 passive mid tops off one channel and 3 channels of low mid. this is where the split amps come in useful.
1250/500
1250/1250
or maybe a 1250 channel for the duel concs if it needs any more welly.
if i run it active, then
low mid           1250/500     HF
2 x low mid     2500/1250   hi mid
still waiting for cones Cry .
Edited by opus jody - 26 May 2009 at 7:14pm
Quantum Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Quantum Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2009 at 1:07am
any news opus?
Clap on the cabs btw they look lovely
Post Options Post Options   Thanks (0) Thanks(0)   Quote opus jody Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2009 at 8:56pm
Temporarily on the back burner, due to not yet finding a 10" high bass cone to die for. also, there's a bit of a carpet crisis going on, ABTT show on now (theatre), 2 touring rigs & a club install in London to build, aaand festival chaos.
I've accepted now that they aren't going to be ready for this season, so I'm just doing the odd 1/2 hour on them at the end of the days work, & looking for more cones.
10 inch,
400/500w,
more than 96dB eff at 100Hz,
60Hz - 500Hz,
copper coil (or copper clad),
neo magnet.
any ideas i haven't thought of?
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2009 at 10:29pm
Faital Pro have some tasty ones that might fit the bill, if you can get them.  Not sure on coil material, but they have models bettwen 3-700watt, good xmax and suitable efficiency.
Post Options Post Options   Thanks (0) Thanks(0)   Quote opus jody Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 1:31am
Thumbs Up
nice, thanks.
Another Italian quality cone builder.
might have to emmigrate.
Watch out for the flu Jeth!
Post Options Post Options   Thanks (0) Thanks(0)   Quote opus jody Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2010 at 6:11pm
cilla.scope View Drop Down
Legs all the way to her bottom....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2010 at 7:24pm
Simply ... WOW .. now THAT is what I call an impressive 3D simulation and rendering package!!!
I mean look .. they have even simulated what happens when some ket-head pokes the dustcap in on the lower driver!!
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ...
