  New Posts New Posts RSS Feed - Old horns on the bay
ollie80 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ollie80 Quote  Post ReplyReply Direct Link To This Post Topic: Old horns on the bay
    Posted: 19 January 2013 at 3:47pm
http://www.ebay.co.uk/itm/2x-Cast-aluminium-HF-Horn-flares-in-boxes-undrivered-Vintage-PA-System-HiFi-/330857464352?pt=UK_ConElec_SpeakersPASystems_RL&hash=item4d08a44220
Look gigged !  Hey Oasis have played through them !!CoolLOL
Ollie K
Nothing is impossible, the word itself says 'I'm possible'
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 4:20pm
Under all that old paint they are pukka JBL 2345 cast alluminium radials. 1inch entry,3-bolt fixing.
oldskool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldskool Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 5:22pm
Ian.
I know, the waiting is killing me. I only need one more pair to complete the HF arrays for the big system.
Politics is the art of looking for trouble, finding it everywhere, diagnosing it incorrectly and applying the wrong remedies
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 1:13am
Sandblasting would do them the world of good.
discodave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote discodave Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 10:38am
Or even soda blasting its less abrasive
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 12:26am
Lead shot wouldn't do the aluminium any harm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 9:07am
There is a thick bitumen type coating on the external surfaces of these under the paint,to deaden the ring,so i would be wary of using any harsh blasting technique.
simonh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonh Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 9:28pm
More old horns....
http://www.ebay.co.uk/itm/vintage-altec-lansing-jbl-multicell-horns-/321059945668?pt=UK_MusicalInstruments_Speaker_Drivers_Horns&hash=item4ac0a9fcc4
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 10:04pm
you can fix that bit what has snapped off easly man i used some kind of liquid metal/puty ect when cured was solid cant remember which one off my head now, but worked a treat file shaped it and re-drilled and counter sinked it... perfect.
just thought id sayBig smile
Edited by Dub Specialist - 21 January 2013 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldskool Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 11:17pm
Could be very useful, one of my other 2345s has a corner snapped off and they will all need stripping and respraying in a few weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2013 at 8:38am
I was only thinking doing the inside of the horn as an easy and neat way of getting rid of the paint Fortunately, with the nozzle, the can put the shot where ever you want it, as it's very directional.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2013 at 9:33am
I bet with a bit of time and effort you could make quite a striking HiFi install with those if you re-housed them creatively
