Round 18" Grilles |
Page 12> |
Meat
Joined: 05 June 2009 Location: Manc Status: Offline Points: 1513 |
Topic: Round 18" GrillesPosted: 29 January 2015 at 5:29pm |
I'm thinking of putting round grilles on my 18" subs and I'm just wondering if I have to make any special consideration in which ones to get as they're very high excursion drivers. Do they even do extra deep ones?
njw
Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2700 |
Posted: 29 January 2015 at 5:39pm |
Had this trouble when I put some waffle grills over some Fane XBs, I used a normal grill but spaced it out with a front gasket from a dead speaker.
lost eden
Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
Posted: 04 February 2015 at 2:07pm |
Electrikal had this issue with PD1851(?) in hog scoops. One gig I was at they resorted to running them with no grilles (was fun to be able to see the cones moving though!).
Meat
Posted: 04 February 2015 at 2:33pm |
Yeah, I remember that and that's why I'm asking actually. Did they find some deeper ones?
Adam_Iron_Horse
Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2041 |
Posted: 04 February 2015 at 7:11pm |
I believe on their new subs they have a wooden clamp for the grill made up that holds the grill and puts a little space between the driver and grill.
I think they also had markie make up round grills for their older hogs as well with a bigger bump in them so the cones didn't touch the grill |
Kryptonik Sound Kollective
www.facebook.com/kryptoniksoundkollective |
markie
Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4568 |
Posted: 04 February 2015 at 9:34pm |
I don't make round grills. If the baffle is recessed deeply enough I can make a box pan grill to the full depth of the recess. Box pan is where all 4 edges of grill are folded to stand the grill off the baffle.
Adam_Iron_Horse
Posted: 04 February 2015 at 11:36pm |
I coulda sworn electrikal told me that you had made the new grills for their hogs!
Obviously wrong but I was so sure haha |
markie
Posted: 05 February 2015 at 12:55am |
Round grills are pressed on a huge machine and there's no room for one in my shed.
lost eden
Thanks(1)
Posted: 05 February 2015 at 2:12pm |
Electrikal posted this to facebook not long ago. Whoever is in charge of their facebook account needs to start posting things here on speakerplans more ;)
Meat
Posted: 05 February 2015 at 2:22pm |
So... ...normal grills but special clamps for the long excursion win. This is exactly the sort of info I wanted. Thanks very much.
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 05 February 2015 at 2:33pm |
It looks like they had an off the shelf grille sandwiched between two rings of wood (painted black) to get it further away from the cone, before it is clamped on.
markie
Posted: 05 February 2015 at 4:35pm |
Here's what I don't understand. Round grills are about a fiver each for the cheap ones (that are almost made on tinfoil) or £9.00 for one made of 1.1mm steel. Then theres £3 odd for a set of standard clamps, so that's £8-12 per cabinet. Then you have to mess around with wooden rings to allow for the excursion.
The above cabs have batten already fitted for a square grill to fully cover the driver. I charge £16.50 max for such a grill which is 1.5mm thick and looks (hopefully) far more professional. For an extra fiver you can even have it powder coated. Doesn't seem to make sense to be but then I am biased. |
Page 12> |
