Golden scan 2 to led |
Page <123> |
Steve20131
Joined: 28 July 2013 Location: Northants Status: Offline Points: 460 |
Posted: 25 September 2016 at 7:37pm |
Led first
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thermostat was on the led base plate. Supposed to run between 55-60c so not too bad
Steve20131
Posted: 25 September 2016 at 7:42pm |
The others will all be 300w and the gs3 500w but externally water cooled, now waiting for parts. I tried the 200w just for a test. While moving them out the led version is way lighter!! a one man carry with the head on
bee
Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4549 |
Posted: 25 September 2016 at 11:06pm |
the led looks sharper with far less colour bleed. looks good.
Steve20131
Posted: 26 September 2016 at 8:00am |
Thanks
getting there slowly
Steve20131
Posted: 26 September 2016 at 10:06am |
Had an idea of complete dismantling, the shells dipped and coated, pcb's checked, flowed and any excess metals cut off...oh and replacing the low power transformer with smps...
Steve20131
Posted: 27 September 2016 at 1:49pm |
No time the 500w is here
montarbo
Joined: 06 September 2006 Location: Germany Status: Offline Points: 9 |
Posted: 27 May 2021 at 2:53am |
Hi Steve,
do you still have you LED Goldenscans? I still have some Superscans left in my warehouse, couldn't give them away. An LED mod might bring them back to business. What LEDs and Optics did you use?
djeddie
Posted: 27 May 2021 at 9:52pm |
He hasn't logged in since December 2018.
Bams
Posted: 28 December 2022 at 10:00pm |
Digging up an old post but i suddenly woke up with 4 goldenscan 3’s in my shed (which is now completely stuffed with obsolete gear) from which 2 are in a semi-operational state.. lots of diodes and driver ic’s are going to be tested and swapped :). Has anybody got any leads on available cobled-boards to replace the HMI’s? When i start googling i end up on rather sketchy led-diy grow your own plant-sites..
djeddie
Posted: 30 December 2022 at 11:26am |
There's several places to get COBs from... but watch out for garbage ones, which are usually cheap and don't last long. Try the usual suspects like CPC, Farnell, RS etc. I started, some years ago, to convert some Abstract Galactic Moons and three of the four 50W COBs I got have already gone. Gave up after that. But there are lots of non-grow-your-own videos on YouTube. One to look for is BigClive who shows why cheap COBs (and LEDs) aren't worth the hassle.
Bams
Posted: 02 January 2023 at 3:39pm |
Thanks for the directions. the idea is mostly about saving weight, they will get only a few hours of use every year so in that view digging up some old stock lamps is cheaper and less hassle
James Tengo
Joined: 09 May 2008 Location: Nomadic Status: Offline Points: 2189 |
Posted: 02 January 2023 at 5:41pm |
It's cooling you need to pay attention too, heat sink plus fans and COB can be done, heat is the killer.
Page <123> |
