  New Posts New Posts RSS Feed - Good old RCF L15P200A
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Topic: Good old RCF L15P200A
    Posted: 07 August 2018 at 7:50am
Got a mint pair for 50 bucks.  Good for Cubo15 or some tapped horn enclosure?  Reflex is out of question because they are boring.
Fs 29Hz
Qts 0.28
Qes 0.3
Qms 10
Vas 280L
Bl 17,2
Xmax +/- 9mm
4 inch voice coil
So according to specs, looks like these might be quite potential drivers anyway.  Does anyone have some experience about these?
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2018 at 10:25am
ported horn? - the Nexo SI2000 bin used a variant of these, and they were highly effective.
fsl.online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2018 at 1:24pm
Make sure your drivers are indeed L 15P 200A and not L 15P 200. The RCF L 15P 200 offered different parameters and, were marketed for reflex cabinets.
Best Regards,
Edited by Elliot Thompson - 07 August 2018 at 1:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2018 at 5:43am
These are indeed 200A models.
That nexo si2000 looks like interesting. However I'm trying to figure out if SS15 tapped horn would suite this driver too!  Tham15 might be too tight/small (not a big difference tho, but SS15 is tuned lower).
Just wondering if this kind of high VAS driver is ok for tapped horn duty?  High compression horns are out of question for sure I think.
Edited by Tonskulus - 08 August 2018 at 5:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2018 at 3:00pm
Tested cubo15 extended with this driver, not good :(
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2018 at 4:50pm
This speaker has so low bl = high excursion:
First 2: compound horn, third one is tapped.
Mixes: https://www.mixcloud.com/gen-ome/
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2018 at 3:47am
Input for the tapped:
Can just adjust Cubo. This one is also with chamber.
Mms is off. To be fair I wasnt sure ts, I picked some of them from 200 AK.
How is xmax calculated here?
Watch inputing there is TH1. Rear of the driver between L23 and L34.
Try to make L12 -> 0
Edited by gen0me - 19 August 2018 at 4:06am
