  New Posts New Posts RSS Feed - HD 15 hole size? PD158
philip banyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote philip banyer Quote  Post ReplyReply Direct Link To This Post Posted: 02 November 2004 at 11:27pm
I will use 2 systems normaly 2 cabs 4 and 4 will make 8 and then run on my DAP amp in bridge mode 1200rms
2nd system 4 cabs
parallel pairs 4+4 = 2 and another 4+4 = 2 and then serial them both of these I think this 4ohms and then use the EP2500 on this.
Does sound right or have a made mistake, if this is wrong then I will have to get another DAP amp (they way about 26kg)
EP 2500 not so heavy may be small power supply
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 12:01am
Do they do a 4ohm 158?  I was taking it that they'd be 8 ohm.
So 2 x 158 paralleled is 4ohms and you want to be putting at least 1200w into them.  Wiring 2 sets in series will go back to 8 I believe and the EP2500 will only give around 1300-1400w bridged into 8ohms running bass, and that would be for all 4 so seriously underpowered.  As I said, the t.amp may well be your best bet if you're on a budget, they come from germany, or try the Warrior xs2500
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2004 at 12:03am
Oh yeah and the PD154 has a higher sensitivity so you won't need to drive it so hard as the 158
