  New Posts New Posts RSS Feed - HD15 honking help
HD15 honking help
dgm606 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgm606 Quote  Post ReplyReply Direct Link To This Post Topic: HD15 honking help
    Posted: 03 August 2024 at 6:41pm
1
Edited by dgm606 - 10 August 2024 at 6:09am
Teadub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teadub Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2024 at 8:37pm
which drivers are in them and what at what frequencies have you tried to xo?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgm606 Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2024 at 1:51am
1
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2024 at 7:05pm
set your upper xo lower, sub 140
also put some more info in your posts please
1ManSoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1ManSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2025 at 1:43am
honk honk ! Tongue
BrainlessTekno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2025 at 8:16am
im glad this post was brought up, lot of interesting info here LOL
BarSick / barsik soundsystem
Dont want to toot my own horn but toot toot
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2025 at 7:16pm
Above graph suggests, flattening eq of approx -3db@150hz, with q of approx 0.5 would be a good start.
If none of the above makes any sense, or you are using horn loaded cabs, without LMS, maybe time to reconsider, if Sound/Mobile PA is for you.
Edited by levyte357- - 02 August 2025 at 7:25pm
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2025 at 11:25am
i used hd15 for 10 years loaded with pd154( mad bl for a 15 inch )  and time aligned to my scoops , i cut them 75 to 125 and they were bloody good indeed
Edited by paulus - 04 August 2025 at 11:26am
TRENDSETTER SOUND SYSTEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2025 at 1:08pm
The HD15 unprocessed response, wil almost always have huge peak in the response, making it difficult to hear anything, each side of the frequency peak.
A lot of older brand name  PA cabs, had a normally peaky, response, but they shipped with  dedicated "controllers", that smoothed the response.
Looking at older Turbo, FK1 docs, they published recommend smoothing eq settings, for  engineers using their own LMS, with these cabs.
Edited by levyte357- - 04 August 2025 at 2:12pm
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2025 at 10:12pm
HeartThumbs Up
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2025 at 4:21pm
using the elderly turbo  tse218/118  I often have a nibble approx -3db at 80hz & 160hz reduces both whoom and honk..
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2025 at 11:48pm
I have a video somewhere, where I flattened the response of a THL-818, after reading Turbo docs, then  using standard Fane 18B, was running the cab, 80-400hz...
