Hd15 - my versioin |
Page <12345 14> |
TDA-Audio
Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
Posted: 16 August 2005 at 5:21am |
fineshed constructhion
http://www.igolkin.com/soft/Tda-audio/images/steck-fas.jpg
PoteirosCorp
Posted: 11 September 2005 at 5:29am |
Hi TDA, I download the LspCAD program; I've done some simulations with reflex boxes, and I am curious about how you simulate this with the Lspcad, (how you put the port??)
Cheers |
MrZuarth
Joined: 11 November 2005 Location: Mexico D.F. Status: Offline Points: 107 |
Posted: 11 November 2005 at 2:43pm |
Sorry, I DO NOT SPEAK ENGLISHMAN Bueno queria comentar, que posibilidad hay de hacer este diseņo del HD-215, pero para bocinas de 18", con bocinas Beyma Mod.18G50. Yo tengo un bafle similar a este, pero veo que tengo que hacer varias adaptaciones... y correciones... pero diganme... como ven ustedes esta posibilidad de hacer una replica del HD-215, pero para bocinas de 18" Deberas, alguien me puede decir , como anexar IMAGENES |
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 11 November 2005 at 4:16pm |
Babelfish translation
Good queria for commenting, that possibility has to make this design of the HD-215, but for 18"horns, with horns Beyma Mod.18G50. I have a speaker similar to this, but I see that I must make several adaptations... and correciones... but diganme... as you see this possibility of doing one talk back of the HD-215, but for horns of 18" Deberas, somebody can say to me, like annexing IMAGENES |
PoteirosCorp
Posted: 17 December 2005 at 8:22pm |
Let me answer him in spanish.
Que tal, el HD15 fue concebido para el mid-bass, asi que no hay una ventaja en constrirlo con componentes de 18". Hay unos modelos de bafles similares, como el ES18 BPH de Staiper, tiene casi el mismo principio de Bandpass horn al igual que el HD15. Ese bafle tiene un f3 de 54hz. Dale al buscador con ese nombre que te di y encontraras informacion. Y otra cosa, trata de darle al ingles porque aqui se maneja este idioma, hay gente de muchas naciones diferentes (holandeses, rusos, rumanos, italianos, ingleses mexicanos, etc...) y todos le damos al ingles aca Saludos PD. te voy a agregar a mi hotmail |
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 05 April 2006 at 9:31pm |
any one want to work out the horn resp inputs for her then? so we can alll see wot drivers will work. some one must be able to sim her up .... |
insert silly sentence here
jethdub
Posted: 17 May 2006 at 6:57pm |
TDA.. with some time passed since you first posted this design, I was wondering if you have anything to report on its performance? I'm particularly interested in the high end response, how high can you play these boxes? Thanks, Jeth
Mark James
Posted: 30 May 2006 at 9:56pm |
i do like the possibilities of suicide mdf rigs made up out of these with some kappa 15lf or similar.....
23kwsound
Joined: 15 March 2007 Location: United Kingdom Status: Offline Points: 20 |
Posted: 24 April 2007 at 9:59am |
Hi are demensions on those plans right cause the baffle only sits 20mm from back is that right
djslacka
Posted: 25 June 2009 at 4:37pm |
has anyone built one of these? they look good to me!
Mark James
Posted: 26 June 2009 at 9:40am |
there is a guy local to me with 4 of these sn15b loaded. I liked em!!! |
djslacka
Posted: 29 June 2009 at 3:58pm |
kl, how was he using them, as a kick bass bin? they could be a good hd alternative
Page <12345 14> |
