Highest amplifier supply rails? |
Page 123 4> |
| Author | ||
BUZguy
Joined: 17 November 2011 Location: South Wales Status: Offline Points: 478 |
Topic: Highest amplifier supply rails?Posted: 06 March 2012 at 10:53pm |
Was wondering what amp has the highest +/- voltage rails in the non tier designs? i.e. single pos. rail, zero and single neg. rail.
Peter Papp [PKN]
Joined: 17 June 2010 Location: Budapest Status: Offline Points: 203 |
Posted: 06 March 2012 at 11:06pm |
PKN 3PHASE-20K +/- 276V
I have not seen any other audio amps with even close values |
Muckerbarnes1
Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2637 |
Posted: 07 March 2012 at 1:55am |
You are of course talking semiconductor and not thermionic.
Billy Dawg.
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 7752 |
Posted: 07 March 2012 at 10:30am |
Have they invented a speaker that can work at that voltage level (or is that a lighting amp )?? |
jbinks
Joined: 27 August 2008 Location: Portsmouth Status: Offline Points: 1310 |
Posted: 07 March 2012 at 10:48am |
I'm sure there is a car-audio "speaker" out there that claims to handle 10k... Would be a fun experiment. In reality however, that kind of amp would be for driving many speakers at once, not just one! So the loads would be connected series-parallel to achieve the best loading for the amp and also voltage across each driver.
Peter Papp [PKN]
Posted: 07 March 2012 at 11:14am |
There are just very few speakers which can handle above 200V peaks. I meant only peaks with super carefully maintained average-to-peak ratio with rms limiter, etc...
The ability of extra headroom compared the +/- 276V to an amp for example an XE6000 with 190V rail (which is still pretty high) is significant even on moderated power levels with smaller speakers too. |
teslaman
Joined: 11 June 2009 Location: Huntingdon Status: Offline Points: 302 |
Posted: 07 March 2012 at 11:59am |
If you mean class-AB with no rail switching (i.e. not class G/H) then i've seen up to +/- 90/100V split rails but there are probably more extreme examples out there (Maplin 1kW amp kit or OMP 1kW MOSFET amp perhaps?). Above these rail voltages it's harder to find decent transistors and more effeciency from class-G/H helps keep dissipation down anyway whilst lowering the maximum voltage the devices see.
Class-D is a different matter of course...
burningbush
Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5885 |
Posted: 07 March 2012 at 1:46pm |
What about a big valve amp, don't they have kV supply rails?
M4trix
Joined: 23 June 2009 Location: Croatia Status: Offline Points: 465 |
Posted: 07 March 2012 at 3:22pm |
I'm a bit skeptic about PKN 3PHASE-20K power ratings. I would like to see the design. Which transistor they used in the output? Transistors that can withstand at least 550V and designed for audio? Unfortunately this is beyond my knowledge.
/me digging on the net about this case.... ![]() |
simonp1100
Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1150 |
Posted: 07 March 2012 at 3:45pm |
1.21 gigawatts per rail.
Sorry i was waiting for someone to say that, thought i would get in there first.
burningbush
Posted: 07 March 2012 at 4:31pm |
Anode supply voltage to KT66 of 475-575v.
Anode supply voltage to V1505 of 2-2.5kV. From the Audio Freq. Amplifier Design book from GEC ltd (London) 1957. |
Earplug
Posted: 07 March 2012 at 6:25pm |
Class D will use switching transistors - usualy fets, not audio devices. {Maybe that´s why they don´t sound right, haha. Just kidding!} ![]() Edited by Earplug - 07 March 2012 at 6:28pm |
Page 123 4> |
