Homemade double 15 reflex box |
ThomasNeron
Joined: 11 January 2019 Location: Quebec Status: Offline Points: 5 |
Topic: Homemade double 15 reflex boxPosted: 01 June 2019 at 1:03am |
Few months ago, I transformed an old furniture into a double 15 reflex box for fun and I was wondering if it would be ok to use it for bass section or maybe sub section before I build two 18" Gsubs. I build it with what I had so there is absolutely no acoustic science in it and I was planning to place two PD156 in there.Here are the approximate measurements :
Height : 39" 1/2 Width : 26" 1/2 Depth : 17" Each speaker holes have their own rectangular port 6" 1/2 under them.(same length as the speaker hole) 14" by 2" 1/2 What if I use it ?! |
JonB67
Joined: 22 April 2016 Location: UK Status: Offline Points: 1352 |
Posted: 01 June 2019 at 9:35am |
Will it make a noise? Yes. Will it be optimal for that driver? Probably not. Edited by JonB67 - 01 June 2019 at 9:46am |
JonB67
Posted: 01 June 2019 at 9:48am |
is the port just a slot or is it a tube (just the thickness of the baffle, or does it have length?)
ThomasNeron
Posted: 01 June 2019 at 12:55pm |
They are only slot, no tube.
Thank you very much fore the replies !
JonB67
Posted: 01 June 2019 at 1:27pm |
if my maths are right your box is about 280litres ish outside dimensions. Once you make a port and add that in (and then subtract the volume of the port and probably 4 litres each for the drivers to give the net volume of the cab ) youre in the rough area for a double 15 sub.
Worth having a go with winisd and getting the port correct and you'll have a decent cabinet!
