  New Posts New Posts RSS Feed - Homemade double 15 reflex box
ThomasNeron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThomasNeron Quote  Post ReplyReply Direct Link To This Post Topic: Homemade double 15 reflex box
    Posted: 01 June 2019 at 1:03am
Few months ago, I transformed an old furniture into a double 15 reflex box for fun and I was wondering if it would be ok to use it for bass section or maybe sub section before I build two 18" Gsubs. I build it with what I had so there is absolutely no acoustic science in it and I was planning to place two PD156 in there.Here are the approximate measurements :
Height : 39" 1/2
Width : 26" 1/2
Depth : 17"
Each speaker holes have their own rectangular port 6" 1/2 under them.(same length as the speaker hole)
14" by 2" 1/2
What if I use it ?!
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2019 at 9:35am
Will it make a noise? Yes. Will it be optimal for that driver? Probably not.
Spend a couple of hours learning the basics of winISD. Its a free download and an evening will have you able to answer your own question properly.
Edited by JonB67 - 01 June 2019 at 9:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2019 at 9:48am
is the port just a slot or is it a tube (just the thickness of the baffle, or does it have length?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThomasNeron Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2019 at 12:55pm
They are only slot, no tube.
Thank you very much fore the replies !
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2019 at 1:27pm
if my maths are right your box is about 280litres ish outside dimensions. Once you make a port and add that in (and then subtract the volume of the port and probably 4 litres each for the drivers to give the net volume of the cab ) youre in the rough area for a double 15 sub.
Worth having a go with winisd and getting the port correct and you'll have a decent cabinet!
