  New Posts New Posts RSS Feed - How do you wire your scoops?
bambaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bambaman Quote  Post ReplyReply Direct Link To This Post Topic: How do you wire your scoops?
    Posted: 24 February 2026 at 12:53pm
Hi peeps, how do you guys wire your scoops?
Do you zig zag the cable through the horn path? Do you fix it with cable clips? Do you make a small hole in the baffle?
Thanks 😊
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2026 at 5:42pm
In general, the shortest path from A to B. If that means going thru internal panels, so be it. Small holes is then sealed with a sealent. NOT silicone based!
fat_brstd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2026 at 10:21pm
I zig zag the cable through the horn path because its easier to do that drilling holes and filling them but I am lazy and either way will work. Just make sure you leave enough slack on the cable so that you have enough length to take the driver out whilst it is still wired in.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
facebook page
BadmanSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadmanSS Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2026 at 1:50pm
Do you staple them in?   I'm currently at this step in my build and I'm not sure if I should attach them to the baffle or do a hole through.
I still have my one side off because of this.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2026 at 2:08pm
I have never seen a commercial cabinet where cables are stapled.
If the wires don't have a straight path from input socket to speaker, then the wires has always been put thru holes in panels and firmly fix with some kind of hot clue.
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2026 at 4:20pm
I've seen cork used to good effect as well in stead of glue
Old OHM TRS 218 did this
Edited by KDW32 - 01 March 2026 at 4:21pm
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2026 at 9:58pm
Uumm...   Caulk  ??
I still have most of it left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2026 at 8:56pm
Uumm...   Caulk  ??
No cork like in wine bottles used like a bung. Unusual but was effective.
Think we might have lost a few posts.  I'm only seeing posts from 24 hours ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2026 at 9:11pm
Uumm...   Caulk  ??
Yes, I did reply to you saying that I'd never heard
of that use in speakers.
