  New Posts New Posts RSS Feed - How many X15 for two X1 by side?
nuendo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuendo Quote  Post ReplyReply Direct Link To This Post Topic: How many X15 for two X1 by side?
    Posted: 27 July 2005 at 4:42pm
For two X1 by side, how many X15? Thank.
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2005 at 5:20pm
If you've got 2 X1's per side then 4 X15's should be enough.  You might even get away with 2 depending on how high you cross
Edited by norty303
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuendo Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2005 at 12:52am
I think I will cross near 70Hz
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2005 at 8:51pm
I think 100hz cross over point would be better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2005 at 12:24pm
I think i'll go for 80hz....
Who's next?
And is there a prize for the closest?
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2005 at 8:45pm
Id go for it depends for the music being played and where the weight of the kick drum is.
Jogge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jogge Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2005 at 5:28am
I use the X1's with X12's on top for dance, rap, hiphop music with one X12 per X1.
The crossover frequencies are set to 90Hz and 1.8kHz which gives us a nice warm sound.  The X1 X12 combination is not very suitable for techno though ...
update:
Forgot to mention i've set the HPF on the LMS to 35 Hz for the X1.
Edited by Jogge
Always listen to experts. They'll tell you what can't be done and why. Then do it.
