I guess i'm no carpenter |
Page <123> |
breakdabeat pete
Joined: 10 March 2008 Location: norwich Status: Offline Points: 758 |
Posted: 19 August 2008 at 2:46pm |
i think if you are going for 8 a table saw is worth the money
٩(̾●̮̮̃̾•̃̾)۶
studio45
Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3881 |
Posted: 19 August 2008 at 5:47pm |
I tried to do mitres without a table saw the first time, tried belt sander, plane, 45 degree router bit, nothing does it properly. Now I've got a £40 eight inch Titan tablesaw from Screwfix that I've mounted into a larger table so i can cut full sheets. As long as I take care to completely ignore the markings on its angle gauge and use an angle measurer, and make test cuts, it works really well. Blade tends to vibrate if you haven't got the fence exactly parallel, which means sometimes the panel will be a mm or so out. But far superior to anything else and, like i said, £40.
doober
Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1123 |
Posted: 19 August 2008 at 8:35pm |
I made a guide for a £30 130mm skillsaw. It takes a cut or two on a scrap piece to get the angle and length stop set right, then I can do as many identical cuts as I need.
Whatever cutting tool you use it'll take a few goes before you can get consistent accurate cuts. I always draw out a full scale plan of the horns internals then cut the pieces to fit it. It's more important to get a good fit between all pieces then to be spot on with the plan. Kieran |
Blahblahblah
Saul
Posted: 20 August 2008 at 4:46pm |
Look into buying a festool. They are guided hand saws similar looking to the pic above, but they are ridiculously accurate and give an ultra-clean cut too.
djtecthreat
Joined: 14 July 2008 Location: MA (USA) Status: Offline Points: 119 |
Posted: 20 August 2008 at 4:50pm |
Thanks for all the tips guys. I've tried to figure out a way to seal it up as best as possible, and I can use it around the house for low end. Definitely not gig worthy.
In the mean time, I talked to my uncle who used to be a cabinet builder and doesn't build things unless they're right. His work is 100%, the only down side is- he's about 400 miles away. But it may be possible for him to build them and I finish them off. -Jim |
Deadbeat
Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Posted: 20 August 2008 at 5:17pm |
Festool make some pretty amazing saw/guide rail combos...
You could make him do the cutting and make some flat packs... If he is a cabinet maker, it is worth requesting rebating (cutting grooves) in the two side panels so the rest just slide in. |
Away on extended leave.
Caeraphym
Joined: 02 May 2008 Location: UK Status: Offline Points: 38 |
Posted: 20 August 2008 at 5:44pm |
Measure twice cut once innit.
odc04r
Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5469 |
Posted: 20 August 2008 at 6:36pm |
Maybe you could have a trip up for a few days, pay him for the materials and buy a few beers (or whatever his vice is) and go about putting one together or at least cutting all the pieces and fitting them for accuracy before assembling back home. Or perhaps even just try a smaller one off design to get more tips from someone who knows whats what. |
cravings
Joined: 30 January 2007 Location: Ireland Status: Online Points: 7507 |
Posted: 21 August 2008 at 2:29am |
festool saw is definitely on my shopping list. unfortunately, it's a fair way down it..
djtecthreat
Posted: 25 August 2008 at 11:22pm |
Well, I got anxious and I threw the sub together quickly and left out
the bottom bracing, just so I could hear the potential. Then I just
put an EAW 18" i had laying around in there, and screwed a piece of
wood over the opening with some gasket foam.
My little brother wanted to sit in it. So heres that picture. ![]() Sorry for the camera-phone picture. I'm INCREDIBLY impressed by this sub even with the 100's of leaks, wrong angles, wrong sub woofer, and under-powered (500 QSC watts). It really punishes. Maybe if I can just get a grasp on the wood-working I can make some really impressive low end with this design. |
odc04r
Posted: 26 August 2008 at 1:36pm |
That's the spirit. Glad to see you got it finished regardless.
A gluegun is very good for sealing minor leaks btw. |
MR-FIZZLE-89
Joined: 03 February 2012 Location: Sutton Bridge Status: Offline Points: 76 |
Posted: 10 March 2013 at 6:32pm |
Page <123> |
