I need a smoke/haze machine |
Page <123> |
wasup
Joined: 26 April 2007 Location: Bahrain Status: Offline Points: 295 |
Posted: 17 October 2008 at 2:11pm |
A couple of three RASTAS and a few waterpipes will do the trick! Write it all down and thats the timing sorted,.....
a butterfly can cause an whirl wind!
Plant a sead and JAH WORKS BE DONE!! |
CHAMPION
Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Posted: 18 October 2008 at 11:50am |
couple of Rasta's should do the trick...
Sticks n Stones
Heathrow_B_line
Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7339 |
Posted: 09 December 2008 at 10:35pm |
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 09 December 2008 at 11:38pm |
not sure that will be anywhere big enough for over 1000 people venues, but in reality you will unlikely get anything bigger than that so is all good.
Id have got a hazer personally, its much more functional, more venue friendly, and just generally more pleasant for all involved.
For reference, the internal heating element and pumping mech in my machine which you have seen is scrumped from a magnum 2000, the model twice the size of the ZR22.
csg
Joined: 17 September 2007 Location: bedford Status: Offline Points: 6085 |
Posted: 09 December 2008 at 11:43pm |
well,with a good fan, the 22 will do haze for venues of 2000+ - i know, ive done it!
unless you can afford a proper oil cracker like a df50, then the best way to go is a decent smoke machine which you can run low continuously, and a really good fan
water based haze machines are only small moke machines with fans, and a big price tag
Heathrow_B_line
Posted: 10 December 2008 at 12:03am |
i just want a nice fine covering of thin fog/haze not plumes of white smoke
if i dont find another zr22 i might get a magnum 2k
but i would have to research how reliable they are first
Heathrow_B_line
Posted: 10 December 2008 at 12:10am |
Pat i have done some reserch... are you sure the magnum 2k produces more smoke? looks quite close on paper. explain yourself young man ps. i hear JEM is a better brand and martin smoke machines werent that good |
csg
Posted: 10 December 2008 at 12:15am |
same factory these days - spend your money on a proper blower, not a desk fan,
im covering a 100 by 25m marquee with my trusty effects company supersmoke 1000 running at 25% tonight - and thats a smaller machine than the 22
Djdarch
Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1989 |
Posted: 10 December 2008 at 12:18am |
hi mate the magnum 2k is no better than the zr22 you have, i would say the zr22 was a better machine , reliabilty of the magnums may be an issue, a local hire company had 3 , all are now out of service.
Having said all that, i have a zr22 thats flightcased thats stopped working, it used to work a ok and really blast out the smoke, then got a bit hit and miss and would only heat when it wanted to. Now it doesnt work at all, i was thinking that it needs a new heater block or can they be repaired??
H...
Joined: 21 July 2008 Location: UK Status: Offline Points: 1164 |
Posted: 10 December 2008 at 6:46am |
Windy fans can be triggered by dmx me seems to remember
pk1964
Joined: 21 February 2008 Location: Warrington Status: Offline Points: 269 |
Posted: 10 December 2008 at 8:57pm |
nice to see the machine as a good new home
Posted: 11 December 2008 at 3:12pm |
take the lid off and have a good poke around. Its a very simple design inside, quite possibly just a contact filled with sticky glucocrud or something thats gotten a wee bit warm!
Page <123> |
