Is a crossover enough? |
Page 12> |
tekcsedi
Joined: 25 November 2015 Location: Romania Status: Offline Points: 24 |
Topic: Is a crossover enough?Posted: 25 November 2015 at 6:02pm |
I'm in the process of getting some HD15's and loading them with Fane Sovereign 15-400 LF, as the specs mostly match what should go into one of these boxes.
Now for my question.A reputable person told me that I will most likely damage/destroy my drivers by only using a crossover,and not a DSP. Bare with me,he told me that I should high pass my HD's to 50hz.I'm still sort of new,only operated smaller systems before,and never used an x-over.Is it not in the capabilities of a crossover to high pass my bins?The person also mentioned something about the HD's needing EQ correction points.I'm sorry if I'm not making this clear,translating technical terms is a total bitch. If I do, indeed need a DSP, is there a workaround?Like getting maybe an equalizer and crossover? Sorry if this seems a tad bit incoherent, not being able to understand is extremely frustrating. |
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 25 November 2015 at 6:18pm |
By cross over you mean active not passive rite?... if so a crossover will be "ok" but you really want something you can set delays with to get a better result. You wont destroy them but you also wont get the best sound you can out of them. A crossover is a good start and a cheapy like the berry 3400 has a delay function so you will get a better result then mst crossovers.
If you mean passive crossover... then dont both building HD at all. Lol |
tekcsedi
Posted: 25 November 2015 at 6:23pm |
So,I should pick up and active cross over first.As I understand it, this will enable me to set the frequencies to where they need to be.
Aside from an active crossover what should my next purchase be? Thanks |
tekcsedi
Posted: 25 November 2015 at 6:31pm |
But,wait,why would I need delays?I'm going to be stacking 4 HD's,eventually 6 with a pair of good tops.From what I can gather you would use a delay in case of different types of subs.
Edited by tekcsedi - 25 November 2015 at 6:33pm |
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7508 |
Posted: 25 November 2015 at 7:02pm |
tekcsedi
Posted: 25 November 2015 at 7:21pm |
Finally something that makes sense in the last 48h. Don't have one.I'm open to suggestions.Guess I'm getting one with delay. Anything else I would need for the system to sound proper? |
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 25 November 2015 at 7:27pm |
you can't set any decent highpass on a simple active crossover. All of them have no highpass or a25 Hz highpass.
It's stupid to use something like that on a horn. You'll blow the speakers on your first event. |
tekcsedi
Posted: 25 November 2015 at 7:47pm |
And a DSP can do that safely,I presume?
Also,when you said EQ correction points,did you mean the delays? To recap, I would need to do the following things to get the sound right and not destroy my drivers: -Delay -50hz Highpass -Coupling the horn mouths properly Did I miss anything? |
Andy Kos
Joined: 15 May 2007 Location: Southampton Status: Offline Points: 3043 |
Posted: 25 November 2015 at 11:32pm |
....and then phone the person you bought them from and try to get them replaced under warranty claiming you only ever used them at half power at a christening. (I'm not joking either.... this has happened) |
AlmostSalty
Posted: 26 November 2015 at 10:58am |
+1 on the dsp, you'll get much more out of your speakers, you'll have your delay, your x-over and eq all in one. What will you be using your system for?
tekcsedi
Posted: 26 November 2015 at 11:03am |
I'll be getting a DSP for sure,eventually.
Mostly outdoor parties,planning to follow the caravan in the summer. |
all bass
Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1845 |
Posted: 26 November 2015 at 12:22pm |
Don't get it eventally, get it now! No proper lms with highpass is a recepy for tears and a lot of shredded drivers. Borrow one for the time being, don't waste your money on an active crossover! |
Page 12> |
