  New Posts New Posts RSS Feed - JAMAICAN COOKIE CUTTER SOUNDSYSTEMS
 Post Reply Post Reply Page  123 9>
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Topic: JAMAICAN COOKIE CUTTER SOUNDSYSTEMS
    Posted: 28 March 2018 at 1:16am
Joined a couple groups on FB. I can't believe how 9 out of 10 yard sounds have exactly the same setup. Selenium type mid tops with a line of bullets in them, stacked on top either 'canadian' type double 18 minis or double ev T18 style cabs. I come across the odd scoop here or there and the occasional folded horn. https://ibb.co/eito27
Edited by RealitySound - 28 March 2018 at 1:19am
Enough with the bass jokes, Just drop it.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:54am
When did scoops go out of fashion?
Not a BPH or folded horn to be seen......
I don't get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 1:58am
Found a couple scoop stacks, not sure if they were from yard though.....
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 7:23am
Imitation is the most sincere form of flattery...
"Battery Acid Sound System" blog hopefully happening in 2017
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2018 at 9:23am
Followers of fashion indeed.
