JBL 2242H in 186 or big reflex? |
Page 12> |
Hugo Biermann
Joined: 05 February 2005 Location: South Africa Status: Offline Points: 809 |
Topic: JBL 2242H in 186 or big reflex?Posted: 06 March 2007 at 7:02am |
We have 4 of these 18's laying around doing nothing. EBP is 120 and BL is 23. Do you guys think they will survive in the 186. The other option is a normal old 170l box. JBLMAN, ROG??
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1563 |
Posted: 06 March 2007 at 11:23am |
Really depends on what you're going to use it for.
186 horn, will not go low as stand alone but will be much louder as reflex, will go lower in stacks. With 4 in stack, preferably used for large parties inside or medium parties outside.
Basreflex, will go low standalone, can be used standalone, larger stacks will only improve SPL-wise. Preferably used for small to medium/large parties inside or small/medium parties outside.
The above should only be implemented as a rule of thumb.
Wkr Johan
Hugo Biermann
Posted: 07 March 2007 at 9:35am |
I know all of that. I want to know if theyre gonna survive in the horns.
mobiele eenheid
Posted: 07 March 2007 at 1:59pm |
My bad,
Everything looks fine as it is, except that they seem te be on the light side. I think it's a border line case. Personally I would give it a go in small stacks and up to AES-rating, but wouldn't want to be the final judge in this.
Wkr Johan
Hugo Biermann
Posted: 08 March 2007 at 2:18am |
It will be two stacks of two. powered with at leas an 3600vz.
djtosco
Joined: 26 September 2004 Status: Offline Points: 58 |
Posted: 08 March 2007 at 9:24am |
I think there isn't any problem with stack of two, and less than 1000W/cab. The 2242 has a light cone, but it is succesully used in horns, for example in the JBL ASH6118.
Hugo Biermann
Posted: 09 March 2007 at 6:14am |
After looking at the driver again, I decided not to go the horn route. The paper is quite thin... They are guaranteed to be fed well in excess of 1K. So we are just going to put them into some single Reflex boxes. Me thinks the thing will fall apart in the 186...
COWFOOT
Joined: 26 September 2005 Status: Offline Points: 1088 |
Posted: 11 March 2007 at 6:37pm |
Btw: the JBL ASH6118 has dimensions of 22.3"H X 56.4"W X 50.7"D weighs 351 lbs.
My gut feeling is that the 2242 is not an ideal long horn driver.
Insomnia
Joined: 06 September 2005 Status: Offline Points: 1721 |
Posted: 12 March 2007 at 11:20pm |
LEVYTE EMPTY INBOX MATE
Hugo Biermann
Posted: 18 January 2008 at 5:27am |
www.aggressiveaudio.co.za
Hugo Biermann
Posted: 19 January 2008 at 4:13am |
rezsbc
Joined: 21 November 2006 Location: Ireland Status: Offline Points: 358 |
Posted: 19 January 2008 at 2:01pm |
Sorry what exactly do you mean by that? The drivers in the SRX718 and 728 aren't up to it?
Page 12> |
