  New Posts New Posts RSS Feed - JBL 2242H in 186 or big reflex?
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2008 at 4:22pm
No, Not compared to the 2242H's (in the same cabs). Same amps, same test, 2242's = tighter, louder and just better! I have been working with those SRX's for the past 2.5jears. Those bass bins are sh*t, except if you want to create a 40Hz standing wave in the venue....Evil%20Smile
www.aggressiveaudio.co.za
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2008 at 4:44pm
Some proof:
Look at the pic below. If you understand what that is saying you will see that the 2242 is so much better. Yes, The 2268H has more Xmax[according to JBL] but its as deaf as a post. Low No., Low Sensitivity and f**king slow. You waste money to get output out of the ting,what were they thinking when they made those things? Music don't just contain notes below 50Hz!
img402/6794/jblcompwb9.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2009 at 8:51pm
An update on the weekley abuse that these cabs are still enduring. They still sound better than the OEM cab and we cant get them to die either. The boxes needs painting again because the guys prefer taking the home buit boxes out....
Even had the local distributors listening to them in an A/B with the OEM's, and they shat themselves when they heard the backyard built cabs. They couldn't believe how sh*tty the OEM boxes sound compared.
f**k THE NEW JBL KIT
OLDSCHOOL IS STILL COOL!
MartinGajta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartinGajta Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2009 at 6:06am
Please,can you give me bass reflex dimension,I also have two of them on shelf so it would be easy to
make srx clone.Since it is simple bass reflex box I assume that box dimension from their site is ok
to start with...
Thank You
Martin Gajta
Jules123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jules123 Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2009 at 3:19am
You got a plan of the SRX718 boxes? or dimensions?
organeux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote organeux Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2010 at 5:42pm
About JBL SRX 718 and 728
The technology of these cabinets is fabulous, research and knowledge of JBL (more than 60 years) is up to date. Sound is simply perfect, punchy, and incredible of precision.
It would be too much easy to buy wood and building the same, NO, you laugh.
It's not simply wood and ability because JBL would stoped its factory !
It's so much more !
Have great succes JBL pro.
the world leading factory
Post Options Post Options   Thanks (0) Thanks(0)   Quote organeux Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2010 at 5:44pm
It's so much more !
Angry This information is not really serious.
I speak as a real pro sound maker using JBL since 1977.
trance addict View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trance addict Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2010 at 4:40pm
Organeux, you're already a true pain in the ass on pro audio french forums. We're already not loved by the Brits, no need to throw  oil on  fire LOL
Edited by trance addict - 05 August 2010 at 4:41pm
"There are two kinds of fools,
One says-this is old and therefore good.
The other says-this is new and therefore better."
-Bob Katz
that-guy-rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote that-guy-rob Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2010 at 5:18pm
I don't know if this is helpful for this discussion, but I'm currently comparing the spec sheets for the JBL SRX718S and the JBL ASB6118 (an installation model) which uses the 2242H driver.  On the back side of the spec sheets the frequency response graph looks somewhat better for the ASB6118 (2242H) than for the SRX718S (2268H) with a fairly flat response extending to a -3dB point of 35Hz compared to 40Hz.  I came across this forum as I am trying to decide between these two subwoofers for use in a House of Worship.  The ASB6118 retails for $250 more than the SRX718S, but that may be simply due to a smaller market for the installation products.  Here are the two spec sheets:
