  New Posts New Posts RSS Feed - L'acoustics LA8 Amp module repairs
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 9:50am
I've only ever seen camco boards in the LA8, each of the 4 modules are custom for the position in the amp, they are not interchangeable even in the same amp ie you cant swap say ch1 with ch4. They're somewhat better quality than pascal.
Edited by kedwardsleisure - 31 May 2024 at 10:04am
North Staffordshire
brokenjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2024 at 11:16am
the only difference is the length of the cables
i have regulary put them in different postions when working out which were the ones were playing up on the shelf
error 404
voron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote voron Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2025 at 1:55pm
I have a lot of skills of repair LA8 output amp modules and PSU, even in it have burned MCU's...but I'm located in Russia:)
rafavalle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rafavalle Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2025 at 6:56pm
Is there a way to get this amp modules? does camco sell those?
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2025 at 9:59pm
LOL.....D-CLASS IS JUNK.....ALMOST IMPOSSIBLE TO FIND SOMEONE WHO CAN FIX THIS STUFF...D-CLASS = FAKE POWER RATINGS.....D-CLASS = NON-REPAIRABLE....LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 10:04am
thank you for your input.
really useful.
error 404
BrainlessTekno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 10:49am
I get what you mean; it's like the old car vs. new car debate. Fixing a 2010+ car at home is nearly impossible, while older ones often just need a screwdriver. It’s a fair point, but that doesn’t mean we should avoid newer and better technology. For instance i do like D-class more than A-class junk=heavy af broke my back
Edited by BrainlessTekno - 10 March 2025 at 10:58am
BarSick / barsik soundsystem
Dont want to toot my own horn but toot toot
Jan-2T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jan-2T Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 11:01am
Hey Voron, do you have schematics?
I've repaired few class D amps, may want to help.
Music!
Post Options Post Options   Thanks (0) Thanks(0)   Quote voron Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 2:39pm
No, I have self-drawn schematics of some pars of amp, but for my repairs only
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 8:06pm
 Yep, that's why every professional touring and hire company are using class D these days and have been for a very long time, 'cause it's junk...
  I like a big old school toroidal amp as much as the next sound guy but who wants to be lugging those about these days? And repairing them when 20+ year old components inevitably start going pop? It's a bit like a sales rep in 2025 driving a Vauxhall Cavalier.
 P.S; Why are you shouting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2025 at 10:12am
L'Acoustics do a replacement kit for these modules, comes with new screws, tie bases, ties, rivets and instructions etc. There is also a returns form where you should fill out the failure circumstances of the old module, so I suspect they want them back as part of the deal.
But you must specify the channel number you need. The cables have to lie flat and true under each other and are all different lengths. You can't order a longer one and cut it down unless you're ok with IDC connectors and if it's too short it wont reach and the PCB transition header is soldered in making removal tricky.
I would talk to your local L'Acoustics dealer. MAke sure you're sitting down before they tell you the price.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2025 at 10:40am
i have already bought replacements, they are about £400 each.. and will soon be obsolete
hence having so many of them on the shelf.. always CH4 next to the fan
The ribbon cable is easily swapped from module to module, so if you have spare ch1, you could just swap the cable from the broken one and it'll no issues
error 404
