LAMBDA LABS |
Post Reply | Page 12> |
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
Posted: 06 February 2021 at 11:09am |
JonB67
Are you selling this product?
djeddie
If so, as adverts go, it's a great start. Got me hooked from the beginning!
Noyzmunky
Young Croc Joined: 10 June 2005 Location: United Kingdom Status: Offline Points: 1260 |
Some sort of european version of chinglish on the site..... Not quite esperanto...but...
my name is Inigo Montoya...you killed my father, prepare to die!.
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Online Points: 680 |
Nice website. Never knew of an Austrian speaker company before.
The horn loaded mid-top boxes remind me of Meyer MSL-10. |
Bams
Young Croc Joined: 08 April 2009 Status: Offline Points: 622 |
As far as i can trace they grew out of a shed into a supplier of quite nice systems for the club scene eand from there diversified. Their austrian distributor Pro Performance by wolfgang sauter has a cool philosophy that room treatment is equal to a great sound system, so has a exotic mixture of Alcons and pro performance systems with sh*tloads of baffles and such installed..
madboffin
Old Croc Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1537 |
Yes, I was thinking of somewhere between an MSL-10 and a Res 9. Good luck to them, it's nice to see a manufacturer in Austria. Reminded me of my time at the Alt Fabrik in the 1990's... I wonder who the owners are? |
bass*en*mass
the qx 12" lowmids are indeed quite oldskool, not much has changed physically since those msl10s have been developed.. they do work, just like they did in any previous "version", within reason. the MHF of those qx tops does differ a lot to conventional 2"/1" comps arrays though. basically those are multiple cone loaded mini unity/synergy horns, in an asymetrical, arrayable horn, they do work well imho, overall i was not that impressed with those though (edit, not in that configs/circumstances i have heard them, at least..) the 215 kicks are very similar to msl5s, again, not much has changed significantly in terms of whats achievable within passband/volume/spl etc. ;) the dh18s are a "custom" take on a mix of many Danley cabs, its basically a TH, quite similar to the th118 but with a `custom` 4ohm nlw9601 and the adapted mouth options of the dts10/thspud.., tbh. i didnt like them much, tuned too high, nowhere near its `specs`, loads of driver noise too imo the k18 amps do sound clean, no hiss, no rumble, i am not sure about the 3ph tripple powercon input though, its not ideal imo, also theres not a single usefull measurement of those available since they have been launched about 3 years ago.. i highly doubt the informal 4x4kw RMS! at 4ohm figure.. Edited by bass*en*mass - 08 February 2021 at 7:24pm |
andariel
Registered User Joined: 09 December 2007 Status: Offline Points: 29 |
It is some sort of horizontal line array with a fixed angle with a seamless overlap acting as one source. A synergy horn or the MSLs are totally different (point sources) and have interferences in the overlap area of the individual horns. Throw can be much larger with such a technology.
MarjanM
No mater which technology you use, the "throw" will be dictated by the SPL capability of the weakest section in the system. In this case it is either the 2x15 section or the 2x12 inch section. So having gazzilion HF drivers is of no particular advantage to me because the rest of the system can not keep up. Maybe in the marketing department it has advantages. 40 HF drivers in on horn, wooow :). I wonder now saturated is the sound coming out of a single 2/3/4 inch throat. Not sure how big is the throat, but that is the thing you can not avoid. It will get saturated very fast with so many drivers.
Edited by MarjanM - 10 February 2021 at 12:31pm |
andariel
Throw is a matter of technology. It is about how fast you loose SPL over distance and if you keep a linear response at larger hearing distances. It has nothing to do with SPL capability only. At all large format line arrays the compression drivers cannot be strong enough and the limit when you bump up against air losses. For a single cabinet you might be correct, but this is likely not the intention of how the speakers are to be used.
meister_gue
Registered User Joined: 01 October 2010 Location: Austria Status: Offline Points: 62 |
I wonder where you heard them? I heard them at a few different events/locations and always had the impression of them going really low, so I`m wondering a bit. Above the 12" section they are using 8*1" compression drivers and 32*2" cone drivers. Always sounds very clean and relaxed, no matter the volumen, but maybe I never heard it close to a limit...
