  New Posts New Posts RSS Feed - line array projects
line array projects
 Post Reply Post Reply Page  <1 10111213>
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2013 at 10:45pm
Which tweeters are you lot referring to? I am not aware of any that has the right dispersion.
thepersonunknown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thepersonunknown Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2013 at 1:38am
Are u asking me marjan?
If so, and u mean which ones this guy could use then I was mostly thinking of the piezo melded arrays someone mentiond before. I'm not sure how well they work to be honest, but for the budget this guy is talking I guess it coule be a half ddecent way of getting away with using a cheep 2 inch driver on a cheep waveguide. Much better than just a cheep eminench bulle anyway.
If u mean the ones used on the clair I4 then I must say I'm not sure. I did see in the back of one once (on that side) and I can say that they had some kinda fairly long waveguide which I didn't see inside of and they are splayed at an angle from each other so as to be able to fit closer together at the mouth of the waveguide. I have to say I don't know any more about them, but knowing that the first I4s were made from bits out of older S4 cabs then the tweeters are probably jbl bullets. I don't know but.
I must say too, I don't think any of what I said before is ideal either, just a cheep option to aproximate the requirements of a line array
They keep telling me life is short, but its the longest thing ive ever done!!!
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2013 at 12:16pm
Originally posted by Catabo Catabo wrote:
Okay, what driver do you recommend me?
I find that wawe guide for line array
http://www.paudiothailand.com/pdf/products/PH-CL35.pdf - http://www.paudiothailand.com/pdf/products/PH-CL35.pdf
but,  not imported in Romania
Thank you with consideration
Catalin.
We have 20 units in stock in Romania
We don't post it on our website because it's not a speaker meant for the DIY market. These are specialized high performance components aimed at the integrator/manufacturer slice of the market.
Ex Nexus_3
Alex@magnumdisco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex@magnumdisco Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2015 at 1:45pm
Hi do you have the plan for the line arey?
if you could send me a couple of dimensions.. i would be very happy,,Smile
//Alex
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2015 at 5:24pm
8ft x 4ft.
Then just cut to size.
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2015 at 5:54pm
Originally posted by imageoven imageoven wrote:
8ft x 4ft.
..that was childish.... he ment to tell you its 18mm ply!!
...let us know how it turns out.
Sapro2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2015 at 9:11pm
They keep on trying!
Splat Soundsystem
Baby Sham pram Soundsystem
Sapro - SoundCloud
https://soundcloud.com/sapro
DJ Sapro. West country free party DJ and Producer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2015 at 11:18pm
Oh dear, not again.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2015 at 7:49am
Line array with 128 horn-loaded 10's, 128 2" compression drivers, 256 18's.
djk
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2015 at 8:23am
What brand / kind of cabinets are they Dennis?
3 hangs rigged in a kind of cross firing array seems unusual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2015 at 9:11am
"3 hangs rigged in a kind of cross firing array seems unusual."
That looks more like a cardoid subwoofer hang.
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2015 at 10:25pm
doubt it sounded thin in any LA aspect lol
