LjudLahger project |
Page 123 15> |
LjudLahger
Joined: 31 July 2008 Location: Sweden Status: Offline Points: 837 |
Topic: LjudLahger projectPosted: 25 September 2008 at 10:32pm |
After 1000 ideas I finally decided which midcab's I wanted to build. NOT. But here's some pictures of the old idea...
At page 4 you got my new project, an V-shape design. __________________________________________________ I have just build one and it isn't finished yet. Going to in the weekend and build the other one. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And this speakon plates are gonna look awsome ! ![]() Thought about doing handels like this, simple... ![]() It is / are going to be loaded with KappaPro10" + Peavey 22T + RCF H100 + JBL 075 And when the time comes for 4 cabs I'll change the 1" driver to P.audio because this peavey's are old... Edited by LjudLahger - 08 October 2009 at 12:32am |
super-hero
Joined: 29 March 2005 Location: Middlesex Status: Offline Points: 2094 |
Posted: 27 September 2008 at 1:11am |
Very nice, What type of ply are you using? And are you going to use a passive crossover.
I'm not an animal, I'm a human being.
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7845 |
Posted: 27 September 2008 at 11:18am |
i would use DE250 and loose the bullet.
LjudLahger
Posted: 27 September 2008 at 7:53pm |
Thanks! The ply is 12mm with some brown painting or coating...Had 1 sheet laying around and i think that 12mm is enough for the 10" driver...only 9 litres. Active crossover between 10" and 1". Passive at 8000 hz between 1" and JBL. I really like the sound in the JBL 075 and the peavey driver doesn't give much in the high... That's whay I use it ![]() But ofcourse, MirjanM, I would like to have new drivers and plan to, just don't got any $ and want to fire em' up! Edited by SweSound - 27 September 2008 at 7:54pm |
LjudLahger
Posted: 27 September 2008 at 11:39pm |
Today I build the other one. Got pretty nice! More pice for you tomorrow.
LjudLahger
Posted: 15 October 2008 at 7:59pm |
This is what I did today
![]() The conection plates are awsome!
![]() And a pic of what I'm going to load them with.
Deadbeat
Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Posted: 15 October 2008 at 8:04pm |
Nice one. They should look the stuff with some rounding on the edges and a lick of paint.
If you ever get problems with the dispersion of a single bullet, do a swapsies with a slot. |
Away on extended leave.
LjudLahger
Posted: 15 October 2008 at 8:16pm |
My english isn't that good...so what does that mean?
Deadbeat
Posted: 15 October 2008 at 8:19pm |
Bullet tweeters have a very tight dispersion and if you ever find that it's problematic, replacing one with a slot tweeter (which have a much wider dispersion - they are very similar to bullets apart from the exit and so command the same price usually) is cheaper than putting in a DE250.
Or you could array two bullets. |
LjudLahger
Posted: 15 October 2008 at 8:35pm |
I see! Thanks for your advice!
It's going to be very intressting when thay are finished...
And it is hard to pic a design for low freq...
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 15 October 2008 at 8:36pm |
be sure to scrape the coating from the wood so the paint will adhere
LjudLahger
Posted: 15 October 2008 at 8:59pm |
Yes sir, I will!
Page 123 15> |
