LjudLahger project |
Page <1234 15> |
music force
Posted: 15 October 2008 at 9:14pm |
where did you get the plaans for this cab or is it your own design
LjudLahger
Joined: 31 July 2008 Location: Sweden Status: Offline Points: 837 |
Posted: 15 October 2008 at 9:16pm |
It is my own design!
LjudLahger
Posted: 25 October 2008 at 3:52pm |
Sinfinity
Posted: 26 October 2008 at 10:43pm |
Seams like you enjoy the ancient art of eating sawdust as much as i do.
That paint removal looks like a horrible task, well done. |
Matt at ukamp dot co dot uk
wafflesomd
Joined: 21 September 2007 Status: Offline Points: 811 |
Posted: 26 October 2008 at 11:40pm |
I learned to wear a respirator after I would end up with a mouth full of saw dust when I was finished sanding...
LjudLahger
Posted: 27 October 2008 at 6:48pm |
Yeah I've learn that maby remove it before I mounting the cab together...Have to get the paint of in the corners at the baffel...maby a "dremel"?
CLsystems
Joined: 16 March 2007 Location: Birmingham Status: Offline Points: 2736 |
Posted: 27 October 2008 at 8:01pm |
i should imagine, if its on the baffle, and your using a grill, it would be ok just to paint over it.
LjudLahger
Posted: 27 October 2008 at 8:47pm |
You got a point there...but I'm not sure if we are gonna use a grill or not... |
CLsystems
Posted: 27 October 2008 at 11:04pm |
still, its not the kind of area that will get knocked or scraped around. might save yourself buying a dremel....
LjudLahger
Posted: 09 November 2008 at 8:02pm |
Damn, did an big update here yesterday but after the database crash it's all gone...
But the update was about me had ordered things from thomann for two more mid cabs and nice speakerstands holders... ![]() (picture from adamhall) And in this week I am going to order four P.audio BM-D450 from PAP. Also bought this for the paint in the corners, 10£ ![]() And was discussing to do an reflex cab of them because I could get down to 115Hz, full power, airflow under control and no x-max reaching...closed 200Hz... would look like this... ![]() And maby the cables would be in the way, but the air flow wont be huge... Also my biggest fan! ![]() Edited by SweSound - 09 November 2008 at 9:03pm |
LjudLahger
Posted: 13 November 2008 at 9:17pm |
Got some things today...
LjudLahger
Posted: 13 November 2008 at 9:23pm |
Do you guy's think that I should loose the bullit? Maby build a cab you could put on top if you need that little extra? I don't know...If I going to build 2 more, I could build 4 new without the bullit and it will be smaller and lighter....
Help.... |
Page <1234 15> |
