  New Posts New Posts RSS Feed - Looking for new lights
andym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andym Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 3:39pm
Liking those destroyers
supremesoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote supremesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 5:37pm
Martin destroyer............now thats a blast from the past! great lights
Post Options Post Options   Thanks (0) Thanks(0)   Quote andym Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 5:56pm
What's the difference between punishers an destroyers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote supremesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 6:07pm
Both 250 halogen watt and moon flower types. YouTube it mate. Maybe comes down to optics and colour. Always used them in master and slave mode.
Post Options Post Options   Thanks (0) Thanks(0)   Quote andym Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 6:13pm
Sorry I was unclear, I've youtube a them and they look very similar.
Just wonder if any one could point the differences out
lgosdset View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lgosdset Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 6:20pm
I have a load of destroyers, dirt cheap, bright enough, cheap to fix if they go wrong (just buy a load of them and put a couple aside for spare parts) oh and the lamps are not too expensive either.
the only thing that can't really be fixed is the stepper motors, sometimes you can give the end bell a wiggle around and they come back to life, but most of the time you need to replace them.
The punisher is the same as the destroyer, but it has a 'shake' effect. never used one myself.
Edited by lgosdset - 28 February 2013 at 6:21pm
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 6:47pm
What's the going rate for punisher and destroyers?
one life - have fun!
Force fusion pro audio
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 6:57pm
No idea what the going rate is for them, but I have 6 Destroyers, all in very good cosmetic condition.
I may be prepared to let a couple go, how soon would you want them? (I've done my books for this year and could do with not taking any more money before 5th April to keep the tax bill down!)
They did Destroyers/Punishers in 2 versions, one with an ELC lamp and one with a fixed reflector and the cheaper M33 capsule lamp. They did a conversion kit at one point.
Mine are all M33 versions due to the cheaper lamp costs (and same as the Solar 250 so easier lamp stock to manage)
Both Punishers and Destroyers need the lamp relay replacing periodically, it either welds itself closed or open (e.g. lamp always on or doesn't switch on and no click heard when powered up) They're dirt cheap and easy to replace if you can hold a soldering iron without burning your fingers
Destroyers are 5 channel (although I've seen ones which like to have 6 channels when patched) and can run in 1 channel, 5 channel or sound to light mode.
Punishers are 6 channel and will run in 1 channel, 6 channel and auto mode (no sound to light!) despite them being based on essentially the same control board.
That said, I did have a Punisher that ran sound to light! So there are hacks and bodges and different official versions out there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 6:59pm
Cheers for that norty, I'll drop you a pm
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 10:48pm
very true regarding the ego's a new board is £175.00 more than the units cost new....Wacko
Ive binned about 8 now..... down to my last 6.......
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 10:53pm
can you not scan an old board and have them knocked up at 10 a penny and then just buy all componants from ebay or the like and make your own boards?
surely the pic/eeprom can be copied and then uploaded to new chips. save your self a packet and keep your lights alive.
£175 a board?... surley you could make 4-5 of your own for that price and then 8-10 more for another 175.
bee View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2013 at 11:10pm
i never looked into it, the problem is when one part on the board gives up, its like a chain reaction, and you just kepp chasing the faults all over the board.....
The ego replaced the destroyer, and this was replaced by the current range.....
