  New Posts New Posts RSS Feed - lower-mid horn design
 Post Reply Post Reply Page  <1 234
RayVaughn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RayVaughn Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 4:21pm
Originally posted by Timber_MG Timber_MG wrote:
A normal A4 sheet is 80grams per squre meter. That means that a 530 square centimetre cone would weigh in at 4.3 grams. The moving mass includes things such as a voice coil and partly the suspension elements in addition to the cone weight. I'd go with the weight of 53 grams (which is fairly light).
Their compression drivers are even more "reasonably" priced but sound absolutely beutiful.
Where are you getting the 53g from?
The thielesmall.com doesn't seem to list a mms or mmd
Ray Vaughn and on
www.innerfield.co.uk
www.rocketfestival.com
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 5:33pm
I entered the other values into hornresp's wizards. WinISD comes up with a Mms of 59.5g
roborg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roborg Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 5:36pm
If you're gonna play with an MT102 sized cab the aj-horn demo is fairly useful, as it seems to be restricted to a 0.5m horn length, which is pretty much spot on for that cab (PS. model half the cab....) The optimum rear chamber volumes from horn-resp & aj-horn seem to tie in pretty accurately for me, good software all around.
cheers,
Rob
Rog View Drop Down
Rogers Archive Posts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 5:49pm
Funny,
I can model 30 meter horns using my AJ horn.
What version have you got.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 5:51pm
That's mean.
Rog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 6:06pm
This is meaner.
Anyone fancy an 11 meter horn with a Void V18 driver in it.
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 6:25pm
Originally posted by Rog Mogale Rog Mogale wrote:
This is meaner.
I'll go warm up the table saw....  Sort the plans out...
Post Options Post Options   Thanks (0) Thanks(0)   Quote roborg Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2004 at 8:32pm
Funny,
I'm trying the free demo version off their site It's got a few restrictions in it
Now a 30meter horn is something! Makes me think of the plywood tunnel used in the first h-bomb test, 9000ft long with a h-bomb as the driver Alot of noise for a short time....
cheers,
Rob
