Martin Audio H3 |
Page <1234> |
dylan-penguinmedia
Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4542 |
Posted: 02 January 2020 at 3:36pm |
Have a look for some W8’s if you’re going to go more than 1 a side on some WSX’s.
lorenzo31071997
Joined: 30 December 2019 Location: Italy Status: Offline Points: 18 |
Posted: 02 January 2020 at 4:09pm |
The W8 are not bad at all, but in Italy it is not found on second hand. I would prefer to build them, there is no mention of W8 anywhere on the web. As for the H3 / H3 + I already have how to configure the cuts, earnings etc.
Edited by lorenzo31071997 - 02 January 2020 at 4:17pm |
smitske96
Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1217 |
Posted: 02 January 2020 at 5:20pm |
If you searched correctly you would have found tons of information. Including which drivers can be used, and also their correct processing. Nowhere is said that it is very hard to get them sounding right. If you want the best of the cab it will become more difficult because you need the correct FIR processing. PS: it doesn't only have two 12" drivers. The whole cab is mainly designed around the coax HF driver. You can use a 4" VC HF driver laike the RCF ND950 but you don't get the same result. If you go for the PM60 you can use two boxes aside (which would be loud).
Digbethdave
Joined: 16 November 2018 Status: Offline Points: 405 |
Posted: 02 January 2020 at 8:01pm |
I guess your WSX are copies too?
lorenzo31071997
Posted: 02 January 2020 at 8:31pm |
Yes, the WSX are also copies. There are many design plans for the WSX. I had the boxes made by a specialized company that made many of them, the speakers are RCF 18LP300 that fit perfectly Edited by lorenzo31071997 - 02 January 2020 at 8:32pm |
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 7752 |
Posted: 02 January 2020 at 8:47pm |
If you're after some H3's, I have 4 here for sale. You can then open them up and copy to your heart's content.
lorenzo31071997
Posted: 02 January 2020 at 8:53pm |
I'd pay for plans, but I'd like to build pits. Aren't you going to make plans?
dylan-penguinmedia
Posted: 02 January 2020 at 9:35pm |
Not sure which part of “nobody here’s gonna give you commercial plans, it’s frowned upon and a bit shit” you’re not getting.
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 02 January 2020 at 11:31pm |
here you go, this is a great start to reverse engineer. You need to get a 15" 10" & 1" driver in there, and make it weigh 77.5kg. Should be easy to do!
lorenzo31071997
Posted: 03 January 2020 at 12:07am |
I already had these data, did you want to make a joke?
Danny A
Posted: 03 January 2020 at 1:22am |
deleted
Edited by Danny A - 03 January 2020 at 1:22am |
djeddie
Posted: 03 January 2020 at 9:31am |
Whilst it won't get you the H3, but here's a link to find the Peter Morris designs... either the 60 or 90 degree.
Also, why not have a search for the X-TRO? |
Page <1234> |
