  New Posts New Posts RSS Feed - Martin Audio W2 12" Driver replacement
Ayotteted View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ayotteted Quote  Post ReplyReply Direct Link To This Post Topic: Martin Audio W2 12" Driver replacement
    Posted: 23 June 2024 at 9:18am
Hi
I am after a replacement driver for my Martin W2, Anyone know where I can source one
I am in the UK
Thanks
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2024 at 9:54am
Originally posted by Ayotteted Ayotteted wrote:
Hi
I am in the UK
Thanks
What numbers does your driver have written on the back of it?  I think iirc the early W2 used ATC and newer ones had RCF.
APC321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APC321 Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2024 at 3:21pm
The driver code for the W2 (8 Ohm) is listed as DLS 231.
I dont know if this would relate to the ATC or RCF.
Couldn't find anything for sale in the usual places. Replacement driver from Martin would be big money unfortunately.
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2024 at 11:04pm
Can you post a picture?
You should be able to get it reconed, whichever driver it is.
Edited by madboffin - 23 June 2024 at 11:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ayotteted Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 10:18am
It's a DSL231
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ayotteted Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 10:48am
What other high quality speaker could I replace it with.
fat_brstd View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 11:50am
I believe it is a variant of the "ATC PA75-314". No idea which one as that drive came in about 100 different variations.
There are specs for a few different versions on the ATC website at https://atc.audio/wp-content/uploads/2014/01/ATC-Driver-Specs.pdf
To be honest its probably worth giving martin a call given they are based in the UK and might have some info to help you out. They might even have a driver kicking about although given the age of the W2 it certainly would no longer be a supported product.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
facebook page
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ayotteted Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 12:03pm
Thanks for the advice ... I have emailed Martin :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ayotteted Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 1:23pm
Thank you all for your help
Edited by Ayotteted - 24 June 2024 at 1:24pm
Ryan94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan94 Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 1:38pm
Also on the look out for one of these. The others members are correct in saying it's an ATC driver. Martin don't stock them anymore. Have also spoken to ATC and they weren't entirely sure which version the DLS231 was.
If you find a pair of W2 for sale at a sensible price and want to split the cost, let me know.
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 4:15pm
As 'madboffin' (a former Martin Audio employee) mentioned, you should be able to get them re-coned quite easily in the UK and will likely id the driver for you given a decent picture :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ayotteted Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2024 at 5:49pm
All sorted
https://www.recones.com/
Thank for all your replies
