Martin WLX/WMX |
Page 123 7> |
SteveAATW
Joined: 04 September 2007 Status: Offline Points: 1173 |
Topic: Martin WLX/WMXPosted: 13 July 2008 at 6:59pm |
No not asking for the plan
![]() But, given its based on the WSX we can assume long folded horn, but the reflex part interests me. Stasys X has long port path to give the LF extension, but the WLX and WMX just seem to port straight into the rear chamber with fairly short ports. Are they working on a different principle? |
ceharden
Posted: 14 July 2008 at 2:14am |
I've had a chance to poke around a WMX. Couldn't take the driver out to see the throat arrangement but it's probably a typical Martin letterbox. Driver faces the corner of the cab but the horn path J shaped.
Roughly half the cab is horn, half is reflex rear chamber. |
SteveAATW
Posted: 14 July 2008 at 2:20am |
Ah, so presume from that it does not have the same number of folds in the horn path as the WSX?
More importantly, did you hear it in anger and what was the verdict? |
ceharden
Posted: 14 July 2008 at 10:02am |
Only one fold, just at the start. The horn length on the WMX is the depth of the box plus the short U-turn.
I haven't heard much of them in use, only one per side for a wedding but they seemed to do what they say on the tin! Pretty good for a single box. Oh, and the driver appears to be a B&C, probably an 18PZB100. |
SteveAATW
Posted: 14 July 2008 at 11:05am |
£3k subs at a wedding
![]() Forgive my probable ignorance, didn't much sleep last night, is the U turn also the fold like the first one below (ie effectively a ported band pass horn), or is there another fold before it gets to the bend like the second pic. Also, someone once posted some internal shots of the WLX and it had some small triangular ports on the baffle into the horn throat, did you spot any on the WMX or is it just the ports to the cab front? And Clearly I own at visio ![]() ![]() Edited by SteveAATW - 14 July 2008 at 11:07am |
ceharden
Posted: 14 July 2008 at 11:33am |
Ah, actually it wasn't a wedding, it was a band who when I usually see them they're doing Jewish functions. It was actually a corporate do but same setup....
Sorry, I didn't explain well. The driver faces the other corner and is right up to the rear of the cab. Bit like a HD15 but with the baffle at more of an angle. |
Deadbeat
Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Posted: 14 July 2008 at 11:36am |
WLX, anybody?
Away on extended leave.
TDA-Audio
Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
Posted: 14 July 2008 at 12:34pm |
this WLX...
SteveAATW
Posted: 14 July 2008 at 1:27pm |
Where's the actual driver baffle on those markings?
ceharden
Posted: 14 July 2008 at 2:42pm |
It's the thick panel on the lower right hand side. Fires through a letterbox, round and out. Very similar to my ported horns really.
Tempted to give an 18" version a go, would be the same size as my twin 18" reflex boxes. |
SteveAATW
Posted: 14 July 2008 at 2:48pm |
Ah sorry, brain fart - I presume the gap between the baffle and the horn path wall is the port from the chamber into the horn throat, didn't realise it was all the way through though, thought it was a cut out in each corner of the baffle
These actually look like a relatively simple build compared to say the WSX, granted not as simple as a reflex but not loads of stupid angle cuts |
ceharden
Posted: 14 July 2008 at 2:54pm |
That gap is probably just a way of making use of as much space as possible for the rear chamber.
Reflex boxes can get pretty complicated when you start refining the design. These would be nice and easy to build as you say. |
Page 123 7> |
