Martin WLX/WMX |
Page <12345 7> |
richters
Joined: 05 March 2008 Location: Romania Status: Offline Points: 11 |
Posted: 14 July 2008 at 10:52pm |
Looking at the picture, I would say that's not 18pzb100 because of the 18tbx100 style cone. It's close to the old model from b&c 18tbx46 (looking at the alu frame), maybe it is an oem version of that.
SteveAATW
Joined: 04 September 2007 Status: Offline Points: 1173 |
Posted: 14 July 2008 at 11:51pm |
Ok found the pic i was on about. WMX is 4 ports, 2 internal, 2 external. WLX is 2 external ports only. Which I think makes these cabs quite different beasts. Looking at the WMX a bit closer, its beginning to remind me of the Nexo CD18 a little (obv without the cardiod rear driver)
So.... WLX is a ported horn WMX is some weird horn/reflex/bandpass hybrid Looking at Jeff Nine Bars test vid on youtube though if the piece of paper test is anything to go by then the WMX shifts some serious air low down. As does the Nexo, but then the Nexo can't go that high without wallowing. Wonder if Jeff can cast some light on what they sound like in comparison to other cabs (X1 would be the obvious one that springs to mind) |
ceharden
Posted: 15 July 2008 at 12:12am |
Are you sure the WMX has internal ports? I couldn't see any when I was looking through the ports into the rear chamber. The Martin website claims it's the same type of loading for both cabs and I've only ever seen ports to the outside on their cabs.
Can you show us the picture? |
SteveAATW
Posted: 15 July 2008 at 12:27am |
Sure, courtesy of TDA's photofiles:
![]() Unless there's something going on behind the baffle which boxes it all off and encloses the throat there's two triangular ports either side at the bottom - does that look similar to what you saw? |
SteveAATW
Posted: 15 July 2008 at 12:29am |
Second Pic:
ceharden
Posted: 15 July 2008 at 12:47am |
I would say that like we were discussing ref. the WLX, there is a letterbox throat and those triangular cut-outs are just to include the otherwise wasted space in the rear chamber.
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 15 July 2008 at 6:10am |
they're not ports, they're there to use up watsed space to make the chamber bigger
TDA-Audio
Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
Posted: 15 July 2008 at 7:17am |
in Old WLx 18TBX46
IN NEW Wlx 18tbx 100 all OEM name (DLS-xxxx) WMX - is not 4 ports..(2 ports) |
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7844 |
Posted: 15 July 2008 at 10:32am |
So how do one calculate the porting? Simply take the rear chamber as a reflex box or?
ceharden
Posted: 15 July 2008 at 10:44am |
Use Hornresp which can directly simulate this type of horn with ported rear chamber.
TDA-Audio
Posted: 15 July 2008 at 11:07am |
front remove panel
Bespoke
Joined: 20 August 2007 Location: Gone Status: Offline Points: 1886 |
Posted: 15 July 2008 at 2:24pm |
TDA-Audio who are you ?
You seem to have pictures/desgins and info on EVERY cabinet out there
Top Top man ! and thank you for sharing this with us
Page <12345 7> |
