  New Posts New Posts RSS Feed - Martin WLX/WMX
Martin WLX/WMX
 Post Reply Post Reply Page  <1 4567>
justamadman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2008 at 6:16pm
now you just need to run it through Hornsrep with with a V18-1000 and release the plans.Wink
how does the sound differ from the wsx???????
in front of the bass bins baby
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2008 at 2:59am
That will be the day when this site hits rock bottom
TDA is already out of order for copying a new design, surprised he's not had a warning or been banned for what hes done
This site isn't full of low lifes is it?
wafflesomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2008 at 5:10am
WSX plans are ok but these aren't?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2008 at 5:19am
no it isn't ok. WSX is an old design, but is still being sold, and these are the new replacements, bang out of order
ASS pland were never put up! is it because Tony was on here?
you guys are funny
it says...SPEAKERPLANS.COM, not .....commercialspeakerplans.wrong
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2008 at 3:08pm
I agree Mykey. No matter how good a clone is - it's still a clone. A martin 215 clone is fine by me (I mean - think of all the free plans that were virtually identical to them released by the driver manufacturers), WSX is pushing it as they are still being actively produced, but a WLX? Plans?
TDA - you seem to have a pretty good head and a good set of hands - it's time to put down the measuring tape and take out pen, paper and calculator to use in designing some cabs of your own.
PS
Mykey! Tony has released plans on here before WinkLOL
Away on extended leave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2008 at 4:08pm
have you seen his website deadbeat?
he's does big corporate jobs by the looks of it,he can afford originals
I bet he's going out as originals
someone ask him if we an see his badges? i bet they are spot on
sorry, it's wrong
If i wanted to, i could be driving a XK8 in six months, by doing exactly what hes doing
I won't because I want to sleep at night, and design my own, its much more satisfying than money when you achieve a great cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2008 at 7:05pm
sorry, it's wrong
Didn't see the website, but have now Angry
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2008 at 3:06pm
Originally posted by J Nine Bar J Nine Bar wrote:
SteveAATW,  in reply to your private message on the WMX, though I would post a reply here as everyone can read then..
The WMX are sick bass bins, they move serious amounts of air, they are a short horn with ported rear chamber, they sound lovely, they move air like an 1850 horn/looney bin but sound more musical and go a bit lower. They don't drop like a lab or WSX as the tuning point is prob about 40-45 hz, but certainly have a faster hit.
I'll try and get a picture of the inside next time I have them out.
i have to dissagree with you on this, unless Martin ARE telling porkies
I did query the specs the other day but no one answered my question
with a -10db @ 28hzShocked  this cab will have a tuning of around the 32/3 hz mk
Amano View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2008 at 11:37am
It is my aproximate drawings... not 100% original values! But...
Edited by Amano - 04 December 2008 at 11:39am
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2008 at 10:44am
Quote It is my aproximate drawings... not 100% original values! But..
is not copy WLX geometry and tuneng wented...
Quote
В теме http://speakerplans.com/forum/forum_posts.asp?TID=18252&PN=7
 я выложил приблизительный чертеж составленный на основе спецификации к WLX и ваших фото, неизвестными остались длина портов и их диаметр. Могли бы Вы заполнить эти пробелы?
Кстати, при моделировании на динамике 18TBX100 не получилось достичь заявленной АЧХ и чуствительности для 1-го кабинета в полупространстве.. Что осталось для меня загадкой как там получается 28Гц при 96Дб чувствительности и 35гц при 103дб?????! .... По видимому графику АЧХ можно сделать вывод что WLX играет ни чуть не ниже чем WSX.
Видимо симуляция недостаточно точно представляет реальную картину...  Confused
Quote
TDA-Audio answear
WLX - good cab !!! (very compact cab) ,  but  not best cab.....
wsx -rullezzz
bh-882 - best bass horn for my...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2008 at 12:19pm
I need know throat area, length and diameter of ports.. And I'll try to draw a new plan of cab, which would be more closer to original WLX sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2008 at 12:34pm
Quote
That was also my conclusion. I have simulated different drivers in a such a box and didn't get any lower than 50Hz. Is there any trick that we are not aware of?
