martinson tham 15 |
Page <1 4567> |
Keen
Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1271 |
Posted: 12 July 2018 at 3:42am |
if you're building 12, why do you need 4 ohm drivers?
Angelow
Joined: 17 March 2010 Location: italy Status: Offline Points: 223 |
Posted: 12 July 2018 at 11:01am |
thanks!
Angelow
Posted: 12 July 2018 at 11:02am |
[QUOTE = Keen] se stai costruendo 12, perché hai bisogno di 4 driver ohm?
6 x side work @ 2,66 ohm [/CITAZIONE] |
Angelow
Posted: 13 July 2018 at 3:37pm |
12db buttherworth? but at the end you have mounted 4 dflectors? or the numbers 1 2 3 4? so like this without cutting the front panel? or was everything as in this picture? Edited by Angelow - 13 July 2018 at 3:37pm |
MagicJohansson
Joined: 07 December 2011 Location: Vantaa, Finland Status: Offline Points: 32 |
Thanks(1)
Posted: 13 July 2018 at 5:17pm |
On the first box we installed all 1, 2, ,3, 4 and 5 but on the second only 1 and 2 and You can not tell any difference in sound. The deflectors do make the box more rigid but even without them its is like a tank.
The high pass is a 24db Linkwitz Riley, the lowpass 12dB LR . I thought about cutting the front top panel as in the middle picture but I don't think it would make any difference in the sound and would only make attaching the front steel mesh more difficult.
AngusR9090
Joined: 09 March 2016 Location: Scotland Status: Offline Points: 32 |
Thanks(1)
Posted: 13 July 2018 at 5:43pm |
Ye is a proper mega strong box.
I think you could easily get away with a 15mm ply or even 12mm ply version with extra bracing.
When I was young.... we still had parties
Angelow
Posted: 14 July 2018 at 9:28am |
I was doing the mk2 because I read it works better with 4 cabinets put together:
I wondered, the panels of the baffles in the blog post are 45 ° while in the rendering they seem different .. What is the correct way to mount them? even the deflectors at the top seem to have different angles from the right angle
Edited by Angelow - 14 July 2018 at 9:55am |
tthorsten
Joined: 22 April 2004 Location: Germany Status: Offline Points: 134 |
Posted: 16 July 2018 at 2:47pm |
what happens if i have other dimensions on the outside and only 15mm MPX i want to build them with 50x70cm and 55-60cm deep.
www.tb-audio.de LEVELchek www.levelcheck.de SPL tracking SATlive www.satlive.audio best Measurementsoftware for Live People DBlimits www.dblimits.com Isemcon EMX7510 measurment Microphon |
Andylaser
Joined: 16 April 2010 Location: Southampton Status: Offline Points: 392 |
Posted: 24 November 2020 at 8:31pm |
Any thoughts on building a pair of these using RCF LF15G401?
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
fatfreddiescat
Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1128 |
Posted: 24 November 2020 at 8:47pm |
Should work just fine, very similar specs.
fatfreddiescat
Posted: 24 November 2020 at 8:48pm |
PS you heard anything form Southwest CNC? think he was based down your way and was making up some good THAM15's at a decent price.
concept-10
Posted: 24 November 2020 at 9:15pm |
He went bust, a few of his customers have come to us, very unhappy people.
Page <1 4567> |
