  New Posts New Posts RSS Feed - Mid hig full horn
Mid hig full horn
Cienfueguero View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cienfueguero Quote  Post ReplyReply Direct Link To This Post Topic: Mid hig full horn
    Posted: 26 November 2013 at 1:02pm
Hi i'm searching plans for 3 way tops 15+10+1(1,4) full horn loaded if is possible they must be trapizioidal. Excuse me for a short topic but i don't speak english. Thank you in advance
discosucks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2013 at 7:03pm
Join the queue haha .
What about An XTRO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cienfueguero Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2013 at 9:25pm
Hallo,
Xtro is very good plan but i like trapezioidal speakers.
I think an xtro whith 2  Beyma 15P80 (101 db 800w rms) 1 Beyma 10 mi100 (102 db 350w) but i don't know if it is possibleShocked.
how i can calculate it? i have never used horn resp.
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 2:15am
Originally posted by Cienfueguero Cienfueguero wrote:
Hallo,
The midrange horn on the Xtro is for 8" drivers, so the Beyma 10mi100 is out of the question...
The XTRO is a great cab but if you are going to change the drivers i would try to very closely match the TS parameters to the recommended ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 3:35am
I found a topic on FSP about this subject, with Hornresp input for both the bass and the mid sections: http://www.freespeakerplans.com/forum/38-hosted-plans/5431-x-tro?
There is a very usefull guide to Hornresp on this forum: http://forum.speakerplans.com/guide-to-winisd-pro-and-hornresp_topic1314.html Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cienfueguero Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2013 at 7:42pm
Thank you for replies, i will work to realize my version of trapizioidal xtro.....God help me!Smile
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2013 at 12:25am
Yup, I've been thinking about the same, if I ever get an order I will post the design I end up with here.
Right now I have tms-2s I even have two copies, this is a nice sounding 15+10+1 cab.
If you're comfortable with hornresp you should be able to calculate & design a cab yourself, I would suggest using the xt8 horn like in the heavy weight suare xtro.
Or take a look at the rcf 10" with phaseplugs (the call it "warhead"!) -still you'll need a horn for that!
