Mid/Tops to compliment 1850s |
Post Reply | Page 12> |
tendril
Registered User Joined: 22 July 2004 Status: Offline Points: 334 |
Posted: 18 September 2004 at 5:51pm |
Which mid/top cabs do you guys recommend to compliment the 1850s?
I'm off to the wood shop next saturday to get my materials for the horns. I intend to build 4 and have them in 1 mono stack. Musically I intend to play house, breaks, dub etc (no Techno or similar music with a sharp kick). If I have them in 1 stack I should get down to 40(ish)hz right? What power will I need to put in if I load them with the void 1000s with the 5" coil? May be looking at a valve amp as one of the guys has a few quid and is biased towards valve. Many thanks |
Tendril
A mistake is a mistake only if one learns nothing from it. |
tendril
ps. being a bit lazy here and can't handle the maths atm:
how many sheets of 8by4 18mm 13layer will I need for 4 horns? |
Tendril
whitehousejamie
Young Croc Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
2 x MT122s would probrably be best. An infinite 8 would power 4 x 1850 horns nicely. For the Mid/Hi cabs, you could use 2 of the smaller Infinite amps, or the Kinetic range. Jamie |
loophole
Registered User Joined: 02 March 2004 Status: Offline Points: 469 |
8 sheets of 8'x4', might need a few extra scraps for small braces inside and the battons on the hatch
tendril
Cheers fellas.
Any build photos of the mt122s coming up in the near future? (@rog) Cheers |
Tendril
Fushion Julz
Registered User Joined: 19 August 2004 Status: Offline Points: 647 |
I built some MT122s just under a year ago...loaded with P Audio SN12MB mids and Beyma CP800Ti tops... Some photos of the build here http://homepage.ntlworld.com/julz_angell/speakers.htm They sound fanatstic, but be prepared for the fact that they are heavy...Dom has built the mids as seperate 12" cabs and the tops seperate from those again... |
tendril
Nice pics julz.
Did you cut access holes in the rear panel or did you make the whole of the rear panel removable? |
Tendril
Andrew
Registered User Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
Great pictures. Would you recommend starting from the inside bits, or build the outer carcase first? Also, would it be possible to take a pair of scales to the MT122 and give us an indication of how much they weigh? TIA Fushion. |
jerre
Registered User Joined: 16 April 2004 Location: Belgium Status: Offline Points: 8 |
@Julz I see you 've used the sn12mb instead of the sn12b, nice to know they sounds good in that design. The reson I find this interresting is that I'm first willing to build the x12's and lateron move foreward the mt122's (the 122's are just to big at this moment to compliment my subs). What subs do u use below them and how much power do you put on them (since a single 12mb is for about an 200Wrms) greets J |
Fushion Julz
The whole back panel is removeable.... |
Fushion Julz
I cut up all the bits first...inside in 12mm ply and carcass in 18mm... Then assembled each horn section onto one side panel starting with the baffle panel and the small ledge/divider beneath it. Then the next bits were the base (inside) lower and upper panels (although the upper one was not glued at that point) of the horn..the one in a single bit..and then assembled the 4 small sides of the horn followed by the top of the horn being glued and then the top and bottom of the carcass. Finally the last side panel was fitted. As for weighing them, I haven't any scales to take the weight! My kitchen scales wouldn't cope, methinks! |
Fushion Julz
***Warning*** Mistype/misprint Sorry, chap, got that wrong...should have said SN12B (not MB) for the 12" drivers... They are 8ohm versions, so the cab is 4ohm in total. Each driver is rated at 300w (so 600w for the cab) and the usually get 1000w each from a C-audio RA4001. However, they have had 1250w into each with no adverse effects.
