  New Posts New Posts RSS Feed - Mini Mini?
Mini Mini?
 Post Reply Post Reply Page  123 6>
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Topic: Mini Mini?
    Posted: 28 December 2008 at 12:51am
After looking at youmy mans fighting and swearing about mini scoops for the past 2 years I finally got to playing around inside the given dimensions. Also took a gander at some of the photos Tek's got up here... I Probably f**ked up somewhere too Sleepy
Well... Aint anything special. 4 will go down to 38Hz with C18-650EL in HRESP.
Parameters:
S1 = 784.8
S2 = 1705.85
EXP = 145
Vtc = 70000
Atc = 2905
Single Plot:
http://img184.imageshack.us/img184/1631/stubbieplotrg9.jpg
Plan:
http://img201.imageshack.us/img201/2776/hugostubbiescoopke0.jpg
www.aggressiveaudio.co.za
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 10:52am
Slightly modified. throats a bit bigger..
S1 = 828.4
http://img510.imageshack.us/img510/3248/hugostubbiescoopv2mn2.jpg
Usable between 35Hz and 80Hz......
High pass 4 @ 30Hz
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 12:39pm
Parameters:
S1 = 784.8
S2 = 1705.85
EXP = 145
Vtc = 70000
Atc = 2905
Single Plot:
TB thanks yet again for your contribution.
But that driver seems to be yielding reflex cab SPL. Confused
boycey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 1:13pm
even though i am a total noob at this and the whole scoop thing isn't really me... isn't the poor sensitivity down to the bits with zero expansion or the negative expansion towards the end of the "scoop" bit?
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 1:28pm
The low sensitivty simulated comes from the path length difference of 145 cm (not so wild guess). The actual path length difference is zero and should yield much better results both in SPL and flatness.
@Three-Bee: Tussen haakjes, moet er geen "w" achter jou?
Best regards Johan
Edited by mobiele eenheid - 28 December 2008 at 1:40pm
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 5:11pm
whats going on with all these MINI Bee scoops..!!
What are you trying to acheive ?
ASS & Shortman's have been proven.
Are you trying to design a mini based on the new Drivers ?? or just adding to the collection ?
Sticks n Stones
(SoundcreationaudiO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote (SoundcreationaudiO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 5:19pm
think he's just using his head, and having a go at something...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 5:25pm
oky if thats the case...i could do with mini scoops which can play high 100-120hz having a punchy kick, and also play low 50hz ? max output volume.
Which mini will do this, small chamber i take it.
i can do with them rather than a double 18 cab
Three bee dont take it in a wrong way.
Good Investigation work..
Edited by CHAMPION - 28 December 2008 at 5:28pm
Sticks n Stones
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 6:12pm
Not so: Ass and Shortman can be as brilliant as you like but they are not DIY, this is a DIY forum called Speaker Plans after all.
 Hapyy New YearBig smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 7:34pm
Looks like there's 0 expansion on the last bit when you look at these pics. I can make it expand if you like though.... Wont change much with the output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2008 at 7:54pm
Here is the SPL Response with the SD18. The 1w response is the same and only about 1dB up on the 650EL.
http://img156.imageshack.us/img156/8126/minispleased18py0.jpg
