  New Posts New Posts RSS Feed - "Modular Horn" by Mr Punisher?
 Post Reply Post Reply Page  <1234 8>
FUBARD303 View Drop Down
Contentiously righteous
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUBARD303 Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2009 at 4:03pm
I really need to sit down n learn hornresp. I so wish I had a graph of theese guys with the reccomended. 18sound 18lf1400 in em. Now my stupider question is...
If the horn resonates down to 35hz when laired and lower when I build all 4 of em, won't the depth be stopped by my driver's 31hz resonant peak? I mean one IS supposed to cut it just above the RP right?
"Always look on the bright side of life" -Brian
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2009 at 5:56pm
These are definitely not correct, I haven't a clue how to use HornResp properly and I couldn't be bothered to work out Atc/Vtc properly so I guessedConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUBARD303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 3:44am
Confused
boycey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 11:10am
darkmatter- where did you take the throat? or where do you reckon it should be? i've been thinking about building a pair of these, possibly modded for a v18 1000. might have a play about with this today.
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 12:40pm
i've calculated the rear chamber to be very very close to 120l, my mac is behaving like a twat though and i can't seem to download pdfs properly, can anyone tell me how much volume the driver takes up?
edit:  and s1=670
Edited by boycey - 26 January 2009 at 12:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 2:24pm
my 105 was a rough estimate based on 119.5 minus driver and handles volume.
start of the throat was guessed by eye, as was horn length, Vtc, AtcEmbarrassed at least it got the ball rolling hehe
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 2:41pm
i'm taking s1 to be the vertical distance on the first fold from the driver- there being no corner piece right of there to extend the horn and bring Vtc down. whaddya reckon?
having an mare calculating Vtc though... if you (or any other helpful person) can riddle me this it would get us there much quicker. my various sine/cosine rule manipulations have given me a headache and are producing results which don't match the plan...
anyways:
we have an irregular quadrilateral, with angles: A=78, B=99, C=159, D=24. side AB=154mm and AD=520mm.
what is the area of quadrilateral ABCD?
i'm off to make lunch
edit: correction to side ABEmbarrassed
Edited by boycey - 26 January 2009 at 4:00pm
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 3:24pm
Split it into triangles...
Away on extended leave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 3:44pm
according to the quite lovely crispy on the urban75 board my quadrilateral intersects itself, hence my issues.
i have put it in hands more capable than my own for now, there's a whole team beavering at this. i'll keep you posted. it should be there quite soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 3:59pm
anyways:
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 4:46pm
ok then, Vtc according to me and crispy is 37.78l
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUBARD303 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2009 at 1:28am
This feels like history in the making...
Cool
