  New Posts New Posts RSS Feed - My BassHorn VS Martin WSX
 Post Reply Post Reply Page  <12345 15>
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 8:48am
Model it using offset driver if you're doing it this way. Try to keep compression low as mykey has said when doing this sort of thing. Otherwise you may be victim to flapping cone disease.
I have the latest version of hornresp and have none of the problems you have - will have a go later - newer versions of hornresp have corrected bass response as you may find. It's not wrong, just more accurate - remember what 0.5 is?
And why are you still calculating in 0.5pi?
Away on extended leave.
Amano View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amano Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 8:50am
http://amanosempai.narod.ru/web/Doc5.htm
What do you think about that? Wink
2 Deadbeat, I calculated only for comparison..
I understand, that 2xPI is normal conditions to play, but i'm trying to test a configuration with different ANG to get optimal parameters. Smile
Edited by Amano - 07 October 2008 at 8:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 1:23pm
That is exactly the horn i am going to build Smile
Mine is with a 18" driver.
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 2:15pm
its like a stretched out 186 horn
tommysb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommysb Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 6:24pm
Originally posted by mykey mykey wrote:
the area in red is to small, this needs to be deeper, the blue marking should be a solid piece across the width of the cabinet
SO mykey, are you saying that a throat like this will put too much stress on the driver?
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 6:51pm
I would guess with this plan one side of the driver is always gonna tear as the driver isn't loaded evenly
mstep77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mstep77 Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 7:22pm
Amano - Nice design mate.  Always good to see people trying different things Smile
My ideas - If you intend to use it in a stack of four then model in 0.5 pi if on its own then 2 pi.
I would say that a single version would be more manageable and more importantly, it will fit through doors!
I would tend to agree with other people that the throat is too small.  The start of the horn is the throat area which is the SMALLEST point after the throat chamber.  I.e. the right hand edge of mykey's diagram above (if its a letterbox design).
Anyways, nice work, get a prototype built!
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 7:32pm
Matt
Where is your reasoning for this?
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 9:38pm
Quote from mr McBean:
Imagine a loudspeaker positioned in a corner, but not touching the floor or either of the two walls. Now assume that the floor and the walls are three mirrors. Looking into the mirrors you will see seven images of the actual loudspeaker. One loudspeaker has been turned into eight, hence the use of the term "eighth-space" or Pi/2 steradians to describe a corner location. Acoustically, provided that the dimensions of the radiator and the distance from the walls are small compared to the wavelength, then one speaker radiating into eighth-space is the same as eight speakers radiating into free space. Once again, this can be confirmed using Hornresp.
Hope this helps.
Kind regards,
David
http://www.speakerplans.com/forum/forum_posts.asp?TID=11032&PN=12
Blahblahblah
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2008 at 9:41pm
Hope this helps.
Kind regards,
David
Exactly what i've been saying - it seems that there is mass confusion regarding the difference between this and a stack of 4 bins.
everdark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everdark Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2008 at 6:45pm
great development, comrade.
but i'm afraid it's too big bitch to carry.
i'm selling out my wsx's crap to build a compact rig as my backbone demands!
music is the only language I really know
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2008 at 8:10pm
what are you going to replace them with Everdark??
CELTIC SUBSONIC SOUND SYSTEMS
