need opinions on new horn design |
Page 123> |
Sencesync
Joined: 17 April 2005 Location: United States Status: Offline Points: 180 |
Topic: need opinions on new horn designPosted: 21 April 2005 at 7:19pm |
i dont really know the hole concept of horn design so dont be hesitent
to bucher it =]. these are the URLs of the pictures, thier a little
big...(visualy, not file size)
scroll down, pictures have been reposted and now work. if theres any improvments that i can make please sugjest them, like i said im a beginer on horns, this is the best i can come up with right now, and sorry i dont have miter angels shown but i do have them. this horn is designed to use a B&C 18NW100 woofer. Edited by Sencesync |
JJones
Joined: 29 March 2005 Location: United States Status: Offline Points: 20 |
Posted: 22 April 2005 at 9:02am |
I tried to view it, but it comes back "can't be found" Jim |
What?????
Timber_MG
Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Posted: 22 April 2005 at 2:49pm |
Much the same. Perhaps too many views? Darn...must get a host.
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 22 April 2005 at 3:45pm |
you can use mine user : nexus password: bassss if you post a picture, the link should look like this: http://www.nexus.as.ro/picture.jpg |
Sencesync
Posted: 22 April 2005 at 4:40pm |
i cant access the host site. so im going to repost the pictures a diffrent way, i can change the pixel size but you wont be able to see the measures very well, but you will be able to see the basic shapes. i based this design on a scoop style design. but it should be about the same. give me a few mintues and ill have it up.
Sencesync
Posted: 22 April 2005 at 5:07pm |
there, those should show, not the greatest quality but it should do |
Disco Stu
Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2492 |
Posted: 22 April 2005 at 7:24pm |
You dont know much about horn design yet you come up with that?!!!! god i wish i had such imagination! Well the expansion looks quite smooth but i think the horn path might be a bit too long for the mouth size but hey bill fitzmaurices are and they work ok The box is pretty big though youd probably need only a couple per side if the mouth length was large enough to reach extension. I like the idea though maybe someone who is good with AkAbak will be able to comment more on the response of the box Stu |
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
Sencesync
Posted: 22 April 2005 at 8:33pm |
ya, apparently i have one of those...extremly technical minds, even though i might not know much about somthing, i can basicly invision exactly how something is built and what pieces there are just by taking a glance, its kinda annoying really, everytime i look at something the image pops in my head and inturn i can some how explain how its built in the inside with out having to open it up....
that design is based off a mixture of things...: the 186horn, the 1850horn, scoop designs. and with thinking mabey if i enlarge the horn pathway, that it might increase the lower pitch frequencies, because if it travels just a tad longer, the frequency deepens just a tad more, hens, the farther a loud noise travels, the lower the pitch gets, and the bombier it sounds.. so i figured "hey, why dont i do that, enlarge the hole box size its self by a tad, and try to get a lower pitch then the common around 50-55hz, and try to deepen it to near 45-50hz. |
Sencesync
Posted: 22 April 2005 at 8:41pm |
oo and hears another fact for you people, im 17...
Lasse Lukkari
Joined: 09 March 2004 Location: Finland Status: Offline Points: 615 |
Posted: 23 April 2005 at 5:49am |
Don't worry! That's just temporary. You'll get over it. Edited by Vivo |
JJones
Posted: 23 April 2005 at 9:01am |
Nice job on the drawings! Have you tried running the numbers in "hornresp"? I'm concerned that you'll get a drop in the 50-70 range due to length vs. mouth size, but with out checking it,,,, Foldings do look smooth! Tough construction, but if the numbers check out, it should be worth a build! Jim
What?????
Sencesync
Posted: 23 April 2005 at 1:31pm |
righton ok, only problem is where do i get hornresp?
Page 123> |
