  New Posts New Posts RSS Feed - Neutrik Powercon
Neutrik Powercon
audioman1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioman1 Quote  Post ReplyReply Direct Link To This Post Topic: Neutrik Powercon
    Posted: 02 February 2009 at 1:22pm
Hi all,
A Neutrik Powercon is rated at 20A ...
Now i have run my 3 amps via a 4 way 13A extension for years... want to use a powercon now my amps are going into a rack together... there is no reason why this shouldn't be ok.? Im only asking, as those powercons are rather small.. can they really take a 20A load??
djdarren View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djdarren Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 2:02pm
The powecon will take 20a  no probs. Just mak sure you don't connect them when live, there not desgned to do that.  They also make a 32a version now :-) http://www.neutrik.com/uk/en/industry/204_2044822873/PowerCon%c2%ae_32_Amp_productlist.aspx
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioman1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 2:08pm
Fantastic... i figured it would be fine, considering they are rated as 20a, they just dont look it! Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 2:23pm
was chatting to ceharden about this last night. Its due to the old ceeforms having brass contacts, whereas the powercons use a silver plated contact, making a better lower resistance connection which thus means it can be nice and smallSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioman1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 2:35pm
Of course!! Genius! haha!
a1dl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote a1dl Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 7:02pm
IMHO, the 32a powercon is the answer to a question no one ever asked.
The ceeform has long been the industry standard 32a SP connector, everyone has distros and trunks full of 6mm2 terminated with cees.   Do we really want to have to start making up & carrying 32a cee-powercon jumpers, just in case?
smithers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithers Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 7:25pm
i see what your point and although i never use 32a, i can agree with what your saying-
but in their defense people probably said the same when they put their speakon connectors on the market....and now speakons are a proabaly the biggest "industry standard" bit of kit on the PA market, 99.9% of people use them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioman1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 7:28pm
My reason for picking a powercon, was because of rack space... i can still connect to the same load as i would with a Ceeform!
I didn't mean to cause a fuss about it
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 8:46pm
Oh, we like to make a fuss on here!
Just take a standard 4 way extension lead (should be one with a fuse fitted in it really) and wire it to the back of a powercon mounted on a patch panel.  To make it even more useful, wire an outlet powercon in parallel so you can 'daisy chain' other equipment if necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audioman1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 9:28pm
that was my plan, as i have a 1U 16 way panel for D size connectors, wanted to use the last couple for powercons, rather than have to buy a second bigger panel for a ceeform!
thanks matey!
Peter Moller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Moller Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 11:08pm
I use the 32A powercon things inside my amprack - connecting the amps to the distro.. Nice and compact ( and incredibly expensive aswell - http://www.thomann.de/gb/neutrik_nac3fc_hc.htm ) wouldnt even consider them a replacement to the CEEforms, purely because of the price.. But imo they are a great option for wiring inside racks etc. where space can be a problem..
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 11:27pm
Do the amps you have need more than 20a each? Save a bit of cash by using the 20a versions http://www.thomann.de/gb/neutrik_nac3fcb_powercon.htm
