  New Posts New Posts RSS Feed - New 4 channel amp
New 4 channel amp
 Post Reply Post Reply Page  <1 17181920>
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2019 at 9:09pm
Three 1K resistors, wire a 1K in series with pin 2  and pin 3 and use the third resistor to link pin 2 + 3 in the xlr at the amp end, will give approx -10dB and wil still be a balanced line.
Marko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marko Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2019 at 11:26pm
Ofcourse that the gain of the amp itself wont change. I expressed little  bit wrong...
It will have 32 dB gain in regard to limiter setting. He need to set limiters and output gains on the LMS in a way as he has a 32 dB amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2019 at 12:57am
Originally posted by Marko Marko wrote:
Ofcourse that the gain of the amp itself wont change. I expressed littleĀ  bit wrong...
Or he can just type 38 in the dB Gain section on his new processors output channels
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marko Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2019 at 1:09am
And I'm shure he will do that.
My post, altrough will work, was not complety serious hence the smile on the end. I would use this technique only in the absence of all other mentioned solutions. After the warranty period I would probably modify the inputs inside the amp to have all amps on 32 dB gain and not think about it anymore.
citizensc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2019 at 1:31am
Originally posted by citizensc citizensc wrote:
Get a DI box to attenuate the input signal.
Just baught a linea asc48, hopefully that sorts it.
Thats a cheap way to sort it :-)
Aahahah, a new processor has been on our shopping list for a while, lower limiter threshold isnt the only reason for getting it.
italmick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote italmick Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2019 at 1:00pm
has anyone tested this amp on bass section?
HyggeJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HyggeJJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2020 at 8:12pm
I am looking at the 2-channel versions, but they have different power specs from the 4-channel versions.
Andy, have you tested any of the 2-channel amps the same way that you did Q10 and Q7?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HyggeJJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2020 at 12:19pm
Hmm... Not much activity here :-/
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2020 at 10:14pm
If you ask a question of a guy that's not been on here for a month,  on a thread he wrote in 2 years ago,  you might have to wait for an answer.
mrtitolee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrtitolee Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2020 at 11:29am
How does this jam amps compare to Peavey ipr2 series amps
Tee
Post Options Post Options   Thanks (0) Thanks(0)   Quote HyggeJJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 March 2020 at 12:30pm
True.. and I did wait 10 days, before I posted the follow up :)
Edited by HyggeJJ - 23 March 2020 at 12:30pm
Rednya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rednya Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2025 at 2:04pm
I know this is an old thread.....but anyone still using the q7? May purchase one in the near future for my top section. Read the review on page 18 and seems like what I need, but it's a 6 year old review
