new build, almost finished |
Page <12 |
bob4
Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1924 |
Posted: 15 December 2015 at 12:14pm |
Sounds good. It will probably fit that style of music well! Have you tested the wbins yet? |
johnEcash
Posted: 15 December 2015 at 12:18pm |
checked a bit further and the dimensions listed above are the same as ours (not 100% sure about horn), we just left the back corners on our cabinet.
bob4
Posted: 15 December 2015 at 12:27pm |
I have no experience of these wbins, but I suppose a short front loaded horn like this should kick well enough (but yes, that's only a guess). On Dancetech a lower cutoof of 55 Hz was mentioned, so it would probably be lacking in the subbass department if anywhere. That would be a problem with roots and dub, but probably works fine with techno ![]() If the stack is not high enough, you could rotate the upper wbin 90 degrees to get the midtop higher. Or maybe even rotate both wbins if you need to get a lot higher! Don't forget to use a ratchet strap though to fix the stack..... |
johnEcash
Posted: 15 December 2015 at 12:34pm |
thanks for the info man,
what we need now is a crossover + eq or a processor (and yes the rest of the paint needs to be done) and we are running. amps are qsc gx5 for the top and gx7 for the bass cabs
Page <12 |
