New System |
| Author | ||
dickscode
Joined: 24 July 2007 Location: United Kingdom Status: Offline Points: 46 |
Topic: New SystemPosted: 10 September 2007 at 7:19pm |
Thinking of building a system using 2 or 3 Punishers and 1 Porn Horm mk2 per stack. Generally it will be live music with some '80's dance!
Anybody have an opinion whether I would be stretching the crossover points of them both or if they would be ok, don't really want to add another low mid cabinet.
Thanks
rinse
Posted: 11 September 2007 at 12:52am |
I don't think the Porn Horn goes nearly low enough. You could try running the Punishers that high but most claim it doesn't sound that good.
A shame really but some HD15s would do the trick and let the Punishers concentrate on the lower frequencies... |
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 11 September 2007 at 11:01am |
It all depends on what you load the punishers with.
I've heard that the ciare doesn't like it up high
I believe the porn horn goes down to 140?
Discode, is it near-field sound your looking for? porn horns and punishers are really outside Joby's, well the Porn horn I would say is, looking at the depth and dispersion.
The old gals at the back wont be able to chat.
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 11 September 2007 at 11:36am |
I've given ours a go at about 130Hz and they seemed okay, the response is certainly loud enough. |
Sibulus
Joined: 11 October 2006 Status: Offline Points: 901 |
Posted: 12 September 2007 at 2:02pm |
Cab resonance though? We go up to 100Hz, max. Keep it doing what it does best. |
odc04r
Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5469 |
Posted: 12 September 2007 at 11:18pm |
Got 2 stacks of 3 up to 140Hz in a big marquee, sounded fine. Think we even tried 160Hz and it wasn't bad but 140 did sound cleaner.
Inside a hall I just found that 140hz rattled the sh*t out of everything, 112Hz worked well for me there. Edited by odc04r - 12 September 2007 at 11:18pm |
Sibulus
Posted: 20 September 2007 at 7:56pm |
What do you run ontop of them? We use X-tros. |
