  New Posts New Posts RSS Feed - Old school Martin audio fans...
 Post Reply Post Reply Page  <12345>
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Digbethdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Digbethdave Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2021 at 8:42pm
Originally posted by KWB75 KWB75 wrote:
To celebrate Martin audio's 50th year - i thought i'd build myself a mini Martin audio modular stack!
The whole thing is just 10 inches wide x 15 inches high, pair of boots for scale.
215MK3 bass section is a single 5 inch subwoofer (£5 ripped from a Logitech sub!) + 8 inch passive radiator on the back of the cab. Built from 12mm MDF, then 6mm ply outer.
MH212 is 2 x 2.5 inch full range drivers (Also £5 from a Canton sound base!), the top is just for show.
Powered off of a TPA3116 2.1 amplifier.
3 is the magic number on the mk3.
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2021 at 9:58pm
Which Harrison amps would they have used? Thanks
Haha - and maybe some old Harrison amps to drive the thing.   Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2021 at 6:06am
Well - I say Harrison, but you equally could have had other classic old amps, Crown, BGW, C-Audio, Citronic - or of course, Martin's own brand amps as well.  Smile
I just mentioned the Harrisons because I have fond memories of lugging their 5kW and 10kW monsters around, like 30 years ago...  LOL LOL LOL
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2021 at 2:45pm
I used a lot of Harrison amps back in the late 80s and 90s. The biggest one I ever came across was the the Xi2000. Would love to find some info on 5k and 10k ones.
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2021 at 3:30pm
... classic old amps, Crown, BGW, C-Audio, Citronic - or of course, Martin's own brand amps as well.
You could add RSD and HH to the list, but Martin didn't have any amplifiers branded with their name in those days (1980s).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2021 at 5:08pm
Yes - not much info around on those. They were rare. I think that the 10kW was similar to the Crest 10001 in that it worked down to 1 or 2 ohm loads.
And IIRC, the 5kW was 2 x 2kW amps in bridge, ie 4 x amp boards bridged, 2 and 2. That didn't work below 4ohm, but was also a beast. Maybe 40/45kg. And dozens of MOSFETs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2021 at 5:11pm
Ok, yes, true. And Mr. Hill with his very unique designs.   Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2021 at 11:43am
I remember now that Harrison had a K Series that iirc comprised of the K2000, K3000, K4000 and the K5000. These were heavy amps with the K4000 being 3u. Those numbers did not seem to be indicative of the power ratings though with the K3000 (the one that I'm most familiar with) only being 650w RMS per channel at 4 ohms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2021 at 12:12pm
Ok - finally managed to find some info - and photos.
They were the Compu-tek Series:-
http://audiorelic.blogspot.com/2014/11/etapas-de-potencia-harrison.html
Monsters!  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2021 at 12:24pm
Wow! Never even heard of these before. They do look monstrous.
Pinheiro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinheiro Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2021 at 1:11pm
hi all
nº off metric ton´s on the 10000 model LOL?
p.s. nice models on the classic Martin Thumbs Up 5 star job
yours Vitor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2021 at 2:39pm
A couple of PA companies I worked for/with down here used these - to drive ASS systems. Both brands imported by the same guy.
They sounded great - but, as noted in the article I linked to, were not too reliable. Which meant carrying spares, which added to costs, which meant people soon moved on to other alternatives. You can't be crossing your fingers that the amps last the night. Or have to swap amps mid gig. That tends to lose you clients.   Ouch
