  New Posts New Posts RSS Feed - optikinetics K series lens
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Topic: optikinetics K series lens
    Posted: 29 December 2023 at 10:03am
I'm in need of a primary condenser lens (the big fat one) for a K4 projector.  No response from opti and optifanatics.com have been showing them as unavailable for ages.
I can probably approximate the original lenses dimensions from the broken remains but thought it was worth a try here to see if anyone had one.
I assume a condenser lens from a kodak slide projector will be similar and as I have a few of these still this will be my first step if I can't find a drop in replacement.
Thanks in advance.
brokenjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2024 at 9:03am
Try Lucy Nation / Jay Legge or Rod Bubblevision
error 404
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2024 at 8:53am
Have you tried phoning Opti? They’re back in the office now…
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2024 at 7:04pm
The condenser lens from a kodak S-AV 2000 slide projector  dropped straight in. Thumbs Up
I found the dichroic heat shield is cracked too, so I need to replace that as well but I'm sure I have some squirreled away somewhere
This page was generated in 0.045 seconds.
